Rain-X In Washer Bottle?
28 replies to this topic
#16 2-alex-2
2-alex-2
  • 480 posts
  • Local Club: SouthWalesMini club
Posted 16 October 2012 - 12:28 PM
Only Place I have applied rain-x is to my rear window to give it a better chance of clearing
#17 bcjames
bcjames
  • 2,728 posts
Posted 16 October 2012 - 12:36 PM
Does it make much difference on the rear? I was thinking of picking some up to try it.
#18 2-alex-2
2-alex-2
  • 480 posts
Posted 16 October 2012 - 05:02 PM
I think it did but like others have said need to do it right for it to work and with no wiper on the back it last a lot longer so it's worth it as well as the from doesn't last two minuets
#19 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 16 October 2012 - 05:16 PM
I have rain-x on every window but the windscreen and its pretty good in the rain but i find on dewey/frosty morning it seems to make things worse because you end up with lots of tiny beads of water where as other cars on the street have cleared.
#20 R1minimagic
R1minimagic
  • 4,660 posts
Posted 16 October 2012 - 05:18 PM
Rain X is a mixture of alcohols and acetone so not suitable in your washer bottle as it will likely degrade the seals (and react with the bottle depending on what it is made from). Also not good for your paintwork so best to use it as intended.
All it does is clean the dirt from the tiny pores in the glass (too small to see) and the water is then less attracted to it, beads up and runs off, until it gets dirty again.
#21 Cooperman
  • 23,276 posts
Posted 16 October 2012 - 05:32 PM
Used it for years with excellent results.
I even use it on my shower screen at home!
#22 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 October 2012 - 12:48 AM
No acetone. There are volatiles for cleaning and to carrying the other ingredients. It does more than clean pores.
http://www.wired.com...tsinside_rainx/
#23 Spitz
Spitz
  • 1,716 posts
Posted 17 October 2012 - 04:25 AM
RainX works very well.......Important to apply as directed! I travelled 45km a few weeks ago in a medium/light rain. Didn't need the wipers at all ( I was experimenting )
They do make a mix for the washer bottle but it's a different mix....just the name is the same.
Don't put the concentrated stuff in the washer bottle...it needs to be applied correctly...let dry....wipe clear
#24 Doz1971
Doz1971
  • 209 posts
Posted 17 October 2012 - 07:24 AM
Me too! Wife thought I was mad (again)
#25 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 17 October 2012 - 07:04 PM
ive used it on my poly carb front screen on my mini with no probs,helmet when im racing my robins,and again my shower screen
#26 warning634
warning634
  • 489 posts
Posted 18 October 2012 - 06:28 AM
http://www.rainx.co.uk/products3.php
This is the stuff which u use directly into the washer bottle and I use their cleaning product on the screen as well.
Can't say how good it is as I have not driven it in the wet.
Kevin
#27 Naughty 40
Naughty 40
  • Just Joined
  • 270 posts
Posted 18 October 2012 - 06:35 AM
Excellent stuff have used it for a while now,remember to apply correctly for best results,can remember travelling to IMM in Denmark and doing 50 mph in rain with no need for wipers on at all
#28 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 18 October 2012 - 09:36 AM
I've heard a lot of complaints about this stuff in the past, but I'm going to have to agree 100% with dklawson. ALL problems I've heard of have been a result of improper application. It works very well for me, also at low speeds.
#29 mike.
mike.
  • 6,176 posts
Posted 18 October 2012 - 05:34 PM
I've used it once and it worked well, but needed reapplying quite soon. I also use the anti-fog stuff they do on the inside which again is good but only lasted a couple of weeks it seemed.
This video below shows how well it can work I think. I assume its rain X that this screen has been treated with:
Edited by mike., 18 October 2012 - 05:43 PM.
