Rear Fog Light
Posted 13 October 2012 - 01:25 PM
My Mini has recently been in for it's MoT and among some other things has failed due to the rear fog light not working. It's a 1992 Rover Mini Cooper and I was wondering if anyone knew if I could simply just remove the fog light to get it through the MoT (A friend suggested this but I'm a bit unsure about if it's legal without a rear fog light) as I'm a bit short on cash at the mo.
Thanks, Alex
Posted 13 October 2012 - 01:30 PM
Posted 13 October 2012 - 04:50 PM
Posted 13 October 2012 - 07:46 PM
Posted 13 October 2012 - 07:50 PM
Posted 13 October 2012 - 07:53 PM
Posted 13 October 2012 - 09:24 PM
My best guess is that the fuse has been wrongly wired to the brown (permanently live) circuit, or if you have in-line fuses, perhaps the ends of two fuses have become crossed.
Edited by tiger99, 13 October 2012 - 09:24 PM.
Posted 13 October 2012 - 09:30 PM
Posted 13 October 2012 - 09:43 PM
Posted 14 October 2012 - 12:07 PM
Posted 14 October 2012 - 04:22 PM
Posted 15 October 2012 - 10:03 AM
The swich should be fed by a blue/orange wire which comes from a fuse, the other end of which will have a blue wire. These colours are consistent whether you have a large fuse box or seperate inline fuses, and for any dashboard and switch layout. The blue wire is fed by the headlight position of the main light switch, so they should indeed only come on with headlights.
ggrrr..... Im gonna have to look at this again .... I took the original wires and reconnected them - I cant see a problem switch side , I'll have a look at the fuse side and see whats what.
Posted 15 October 2012 - 10:04 AM
does the light on the switch light ?
yeah its the original rear fog switch - when I switch it on it lights up on the switch (as well as the fog obviously).
Posted 15 October 2012 - 11:40 AM
try replacing the bulb
Posted 15 October 2012 - 12:10 PM
NO! That is illegal and a certain MOT failure. There is a prescribed minimum distance between the rear for light and brake light, and you can't achieve that in the cluster, unfortunately.
Is that because its a modification Tiger?? the reason i'm saying this is a lot of modern cars have their fog lights within the cluster which in effect is what this is mirroring. If its not illegal then its not a bad idea.
