How Do People Clean There Clutch Caseing And Gear Box Up ?
Posted 12 October 2012 - 12:47 PM
Posted 12 October 2012 - 01:26 PM
Trac
Posted 12 October 2012 - 01:28 PM
Marine clean >>> Metal prepare
Posted 12 October 2012 - 01:44 PM
http://www.loctiteproducts.com/p/s_trmt_alum/overview/Loctite-Aluminum-Jelly.htm
Posted 12 October 2012 - 02:45 PM
Posted 12 October 2012 - 04:55 PM
Posted 12 October 2012 - 05:17 PM
Posted 12 October 2012 - 05:24 PM
Posted 13 October 2012 - 12:15 PM
- Start with a good degreaser to wash away the heavy oils, road dirt, and grime. Use an old paint brush or similar with stiff bristles to work the degreaser into the nooks and crannies.
- Follow the degreaser with a mild caustic cleaner (If you use the POR Marine Clean above, dilute it with water first. It is strong caustic that will attack aluminum). You can use spray oven cleaner (if it says it is caustic) but like the Marine Clean you need to keep an eye on it as it is often a strong caustic.
- Scrub the caustic in with a stiff bristle brush, keep working it and then rinse it off with lots of clean water.
- Once you have taken the box to that point, use something like aluminum wheel cleaner from the auto parts store and scrub it into the gearbox. You can use the stiff brush again but at this point I typically switch to a small detail brush with stainless steel bristles.
- Work the wheel cleaner in quickly and be sure to use the brush a lot. Don't allow the cleaner to sit idle or you are likely to get a blotchy appearance. Work quickly with the brush then rinse the wheel cleaner off with lots of clean water.
- Hit any isolated spots individually with the wheel cleaner and detail brush then rinse again.
- Use compressed air to blow the casing dry. If you allow it to dry slowly you may get blotches again.
Once the gearbox is dry, apply a clear enamel over the box to protect it. There are some automotive clear coats designed just for bare metal and I have had good results with them.
Posted 13 October 2012 - 02:27 PM
So far I've used it on rusty hubcaps, corroding wheels, corroding bike frame, various other bike parts etc.
Posted 13 October 2012 - 08:27 PM
Posted 13 October 2012 - 08:38 PM
However, don't allow it to dry on a surface you are preparing. Keep the surface moist until you are done with the cleaning process then rinse and dry quickly.
Why is this dklawson? I noticed that it seemed, what looked like the corrosion i had just removed, had come back 10 times worse inside a tube I hadn't washed out.
Posted 13 October 2012 - 08:45 PM
Phosphoric acid is commonly used on bodywork for panel preparation prior to painting. If the acid is allowed to dry on those surfaces the resulting film left behind is loose and does not allow the paint/primer to bond to the panel. Keeping the panel wet followed by quick rinsing and drying prevents that. Many people "freak out" when they rinse and dry the panel because flash rust is almost certain to form no matter how quickly you dry the panel. That flash rust is VERY loose on the panel and is easily removed by wiping down with prep solvent. It is nothing to worry about as long as you don't leave the panel sitting unpainted for days... which would allow real rust to develop again.
Posted 15 October 2012 - 04:18 PM
Which one do you buy? A lot seem to just be fancy soaps for cleaning dirty not oxidised alloy. Be interesting to compare it to my old fave of WD40 and scotchbrite pads.I use 'ally-clean' off ebay for about everything, 28 quids for 5 litres. It's an acid cleaner so must be used only on suitable surfaces, but it removes oxides from alloys and steels, aswell as removing anodized plating. I'm going to use this on my gearbox and casing.
Posted 15 October 2012 - 04:28 PM
http://www.ebay.co.u...984.m1439.l2648
this stuff. I never expected it to take the anodising off, but I found out when I got some on my push bikes handlebars.
It suggests diluting 15 parts water as well, for general cleaning, but I tend to use it a lot stronger than that, but re-use it
