The next one is their Blind Hole Bearing Puller that I used to remove the idler gear bearing and bearing race for the input shaft. I did have to pull in a downward direction to make it work. So, I used a wooden frame cantilevered out from and clamped to a table. I pulled through the middle of the frame and they came out with 3 to 5 hits.
Edited by xrocketengineer, 05 October 2012 - 09:38 PM.
