Does Anyone Know How To Identify A Mk1 850 Mini Super
40 replies to this topic
#31 mk1coopers
mk1coopers
  • 654 posts
Posted 12 October 2012 - 04:48 PM
what are the diffrances?
Liam
Various brackets ect that should be there that don't normally suffer from rust or removal
#32 liam-ds
liam-ds
  • 676 posts
  • Local Club: Barnsley mini club
Posted 12 October 2012 - 06:26 PM
brackets for a boot board?
Liam
#33 mab01uk
mab01uk
  • 12,268 posts
Posted 12 October 2012 - 10:53 PM
Liam
Like the Coopers, Elf, Hornet and some other models I believe the Super had these brackets fitted to floor and rear bulkhead to support the plywood /carpeted boot floor board.
BOOT BOARD BRACKET SET CK948 EQUIVALET
this kit contains all the brackets and mounts that were fitted on original Coopers.Wolseley Hornet and Riley Elf with boot boards fitted as standard. No instructions as some parts need welding in, therefore knowledge of the car and fitment are essential. for use with boot boards CCC110/111/112/113/
#34 liam-ds
liam-ds
  • 676 posts
Posted 14 October 2012 - 08:49 PM
hi everyone i have got some pics of the areas that you asked for and a few others too. firstly the boot is in a bad way has had half a boot floor welded over the original battery box is made of sheet steel over the old and there is a big hole between the battery box and the subframe rear mounts. i have never seen inside a mini boot that has boot board brackets so don't know what to look for or where to look. i have also got some pics of the doors where the little circles are theses a exactly in the centre of the top half of the door and appear to be spaced apart evenly, i also have a few pics of the dash rail and the material that is still left under the steering column mounting
inside the boot
the dash rail
sun visors and roof lining
the doors not sure if you can see the circles in the pic but these have the correct 10 hole sliding runners
i am going to ring up Gerry tomorrow have been too busy to phone him i will also email him these pics to me the car all seems to match up. it has the correct shell for the year etc do if it has had the plates and vin swapped at least i have a correct year shell to work with
Liam
#35 mk1coopers
mk1coopers
  • 654 posts
Posted 14 October 2012 - 09:29 PM
I can't see any evidence of the boot board brackets on the rear bulkhead in those pictures, if you restore it as a Super (depending on the chassis number), it will cost you as much as a Cooper trim wise, so it's not going to be cheap
#36 mab01uk
mab01uk
  • 12,268 posts
Posted 14 October 2012 - 11:31 PM
The filled circles/holes around the upper door frame for Cooper/Super stainless trims would either be quite small for the later pop rivet sized clips or about 5-6mm diameter for the earlier 'tag' style clips which slide in but are no longer available.
See photos here:
http://mk1-forum.net....php?f=3&t=5687
Edited by mab01uk, 14 October 2012 - 11:34 PM.
#37 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 15 October 2012 - 12:58 AM
This is a 1275gt boot which shows the positions of the boot board brackets.
Below were your fuel pump is fitted, it looks like there are a couple of small holes in the rear bulk head?
Edited by surfblue63, 15 October 2012 - 01:11 AM.
#38 mk1coopers
mk1coopers
  • 654 posts
Posted 15 October 2012 - 05:42 AM
I can see what you are saying, but they look to low, he might have to move the pump and take a closer picture square on to the bulkhead
Edited by mk1coopers, 15 October 2012 - 06:16 AM.
#39 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 16 October 2012 - 07:58 PM
The pull cords on the doors are not a Super feature and no evidence of bootboard brackets either.
Not that they are present clips for the top door chromes were swapped for the rivet type from around June 1962.
The switch panel should be grey and it looks like the ignition switch is the floor start type - Supers were key start.
#40 ZEBERDEE
ZEBERDEE
  • 110 posts
  • Local Club: Box Hill Mini Club
Posted 05 January 2014 - 07:59 PM
Hi, I also have a 62 super.
Have you made any progress in finding the missing parts.
Rob
#41 liam-ds
liam-ds
  • 676 posts
Posted 05 January 2014 - 10:37 PM
Rob
hi rob no i havnt its is currently sat in the corner of the garage with all my other projects.i have collected afew mk1 parts that it was missing steering wheel binnacle set up etc. the chassis number matches up with that of a super and the wiring loom minus the push button starter that has been added later in its life is the same as a cooper / super loom. going to be a very expensive resto but looking forward to starting it in the next couple of months once my clubby estate is finished
Liam
