a) getting it welded or
b) getting another tank?
Posted 02 October 2012 - 07:30 PM
Posted 02 October 2012 - 08:35 PM
Posted 02 October 2012 - 08:46 PM
Posted 02 October 2012 - 08:55 PM
Posted 02 October 2012 - 08:57 PM
Edited by dklawson, 02 October 2012 - 09:01 PM.
Posted 02 October 2012 - 11:06 PM
Posted 03 October 2012 - 02:32 AM
Posted 03 October 2012 - 04:52 AM
Ummm when people talk about POR-15 there are a couple of things to be careful of regarding terminology.
POR-15 is an external coating, not for fuel resistance. HOWEVER, POR does make a fuel tank sealer using a similar paint chemistry. Their motorcycle tank kit is the ideal size for sealing the tank of a Mini. The kit comes with small bottles of their "Marine Clean" (caustic cleaner to remove fuel gum and varnish) and their "Metal Ready" (phosphoric acid metal etch). Of course, it also comes with a pint of their fuel tank sealer paint.
I have used several tank liners over the years. I much prefer the POR kit. It is easier to use and does not contain MEK which most other systems use. Prep your tank inside and out. Apply duck tape (gaffer tape in the U.K. ?) to the outside over any pin holes that need sealing. Remove the mesh strainer from inside the tank (on the fuel pickup pipe). Remove the sending unit and make a cover over the opening and have something ready to cover the fuel filler neck. Prior to using the kit, coat a large, heavy stiff electrical wire with Vaseline and insert it into the fuel pickup tube. Make sure it goes into the tank. You will withdraw this later to make sure the fuel pickup pipe remains open. Do the same for the vent tube.
Again, there is POR and there is the POR gas tank sealer kits. Though they are from the same company the chemistry is different. Don't use regular POR inside a fuel tank.
EDIT: Welding a tank is not for the faint of heart. It is also a skill that most people do not have since the tank is thin and these perforations open up at the seams where the drawn metal is extra thin. If you really, really hate the idea of the liner, strip the affected area to bare metal and solder over the area using a large plumber's soldering iron, acid flux, and large quantities of solder. Also keep in mind that the liner is closing a pin hole, just like the weld/solder will. Soldering or welding does not add strength to the tank. You are not better protected by using welding/soldering as opposed to the liner.
Posted 03 October 2012 - 09:14 AM
Posted 03 October 2012 - 09:27 AM
Posted 03 October 2012 - 10:07 AM
That won't be the only weak point in the tank - for peace of mind, just get a new tank. You know it makes sense. As for fiddling about with a soldering iron on a rusty old tank - good luck!
Posted 03 October 2012 - 10:12 AM
Posted 03 October 2012 - 12:24 PM
The one note of caution I would add concerns ethanol. I have a right hand tank in my Cooper that has been sealed with Frosts excellent kit. At the moment it is sealed well and has been for several years, but I have been noting the warnings about ethanol, which will apparently turn the seal to a jelly. Do Frosts have any comment on ethanol?
Edited by dklawson, 03 October 2012 - 12:27 PM.
Posted 03 October 2012 - 01:09 PM
Edited by Big_Adam, 03 October 2012 - 01:10 PM.
Posted 03 October 2012 - 04:05 PM
