Painting A Mini With Hammerite (Brush)
Posted 01 October 2012 - 04:23 PM
If you can put aside issues with looks (I know that's hard) but on a pure logic and technical basis, what are the down sides to painting a mini with hammerite?
The reason I ask is that I fancy a cheap mini purely for the fun of driving it rather than looks or restoration. After all, once you are inside the car, you cant see what it looks like!
Posted 01 October 2012 - 04:24 PM
Posted 01 October 2012 - 04:32 PM
Then after about 10 days from applying the final coat rub it down with first 600 grit 'wet & dry' then 1200 'wet & dry'. Then polish it with a good cutting compound such as 'Ferecla', then with a fine compound like 'T-Cut'. Finally polish with a wax polish and it will look as good as a sprayed finish.
That is the sort of method used to paint pre-war Rolls-Royces.
Edited by Cooperman, 01 October 2012 - 04:33 PM.
Posted 01 October 2012 - 04:34 PM
Posted 01 October 2012 - 04:48 PM
if you search the net for rustoleum you should find a lot of info
Edited by Bungle, 01 October 2012 - 04:48 PM.
Posted 01 October 2012 - 05:05 PM
Posted 01 October 2012 - 05:06 PM
Posted 01 October 2012 - 05:30 PM
Posted 01 October 2012 - 05:33 PM
This company will mix any colour you like. Just give them the BMLC code & Bob's your Uncle.
http://www.tools-pai...cation._7300MC1
You can spray it on or roller it. White spirit thinning for roller & Combi Thinner for spraying. East peasy. Look at Bungle's thread, he did a fantastic job which inspired me to risk £70 on paint rather than £700 on a spray job at 'mates rates'.
Edited by Ocado Man, 01 October 2012 - 05:35 PM.
Posted 01 October 2012 - 05:37 PM
It'll be a bugger to repaint with celly/2k at a later date without bare metalling it, worth bearing in mind
Not necessarily, if you use your original paintwork as a base then having it resprayed would only require stripping back to that, assuming the respray was in celly / 2k. I wouldn't suspect waterbased would be reactive but couldn't say for sure.
The other option would be to use a bar coat first.
Posted 01 October 2012 - 06:10 PM
Edited by pbeardmore, 01 October 2012 - 06:11 PM.
Posted 01 October 2012 - 06:14 PM
Posted 01 October 2012 - 06:19 PM
So what is wrong with using a brush ? (again, we are not considering looks) surely, a lovely thick layer if Hammerite will give some really good rust proofing, and if I get a scratch, I just paint over it? It takes a leap of imagination but beauty is only skin deep.
It does depend on quite how little you care about the finish. A roller is probably faster in terms of application per coat but you would need at least 3 or 4 coats to provide some level of durability.
With a 10% thin you also end up with a pretty smooth finish, comparable to many factory finishes.
The probaly you will encounter in putting on "a lovely thick coat" is it will take a bloody age to dry, even more so now the weather isn't as clement. From rollering mine a month ago I know that you'll get 2 coats on and dry before 1 thick will be anywhere near the same.
Plus you don't have to worry about runs and drips.
As said that's all academic if you only care about rust prevention.
Posted 02 October 2012 - 10:04 AM
