1980 Mini Miglia
427 replies to this topic
#256 rally515
rally515
  • 3,848 posts
Posted 02 July 2013 - 12:20 PM
JESUS!!  its progress!!!!!!!! :lol:  kiding kirb
Get them photographs up asap! :P
#257 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 02 July 2013 - 12:28 PM
She is on all four;)
Teaser on Fb pal:D
#258 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 02 July 2013 - 08:20 PM
weheeyy time to crack on!
now, i have been doing alot on the clubman engine at the moment.  engines pretty much done now apart from some output flange cover bushes...
i dun dis tho. holes are cosmetic only but still.. its been ported out, polished, opened up for better oil flow and generally made less crap. il never ever use one standard now i have looked into them and seen how rubbish the cast is.
now, the ex miglia.
as you know there is a large amont of holes everywhere. i have put the rear subframe on to be able to move the mini around the workshop, so its on:D  looks good aswell!
looks good! will be lower, no weight in it, i can lift the rear end waist height with the subframe on!
and i have finished the brace bars!
they are inch tubing, same stuff we use on the historics chassis, so its strong!
rose jointed either end, the bolts in are temporary, and i have allen bolts on order:) need to make up some spacers for it though, probably 12 by 5 with a 10mm bore.
i made up some brackets for the brace bars, i didnt want to just bolt it to the car panelling, so i made these up, made them look good and welded them on!
and the car currently!  woop!
paint hopefully in a few weeks so i am seriously cracking on, but if i get parts for the clubman engine my attention will be easily swayed, as i want to hear that baby roar, it should have huge power!!!
cheeerrs
Edited by Artful Dodger, 02 July 2013 - 08:21 PM.
#259 afrance94
afrance94
  • 298 posts
  • Local Club: none at the moment
Posted 02 July 2013 - 10:23 PM
looks mint keep it up
#260 johnnyblaze
johnnyblaze
  • 189 posts
Posted 03 July 2013 - 06:23 AM
sexy brace bars mate, are you having them stickers on the side remade so you can spray the whole car and refit the new stickers or do you want to keep the orig stickers and paint right up to them?
#261 leaky
leaky
  • 6,890 posts
Posted 03 July 2013 - 02:02 PM
Looks good! Dont suppose you have a spare 7 inch wide revo do you ;)
#262 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 03 July 2013 - 02:46 PM
Cheers:)
Nope sorry pal;)
#263 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 07 July 2013 - 06:46 AM
moar updatez
I have used a bit of filler to smooth the rear end boot floor out as much as posible. if youhave been following you will know that the way the bootfloor was made, the two metal filler strips that were angled were stepped, so there was a lip. a bit of filler sorted that out. a bit of hand painted etch primer for a base for the seam sealer!
painted and sealed rear end
fibreglass the gaps up in the bulkhead. this is to stop fuel gushing around if i put her on her roof! :D and its what it had originally so back she goes!
I filled that hole in, this was between mixes! :P
(the 'black' is metal that has been taken back to metal, just shiney!
rear harness bar being made up:)
this is fairly beefy, should act as a brace bar for the rear damper mounts aswell :) all tied in with the cage!
rear towers welded for strength, cant have these ripping off!
cheers8) should be ready for paint in a week or so!
Edited by Artful Dodger, 07 July 2013 - 06:48 AM.
#264 rally515
rally515
  • 3,848 posts
Posted 08 July 2013 - 01:24 PM
Nice to see even in 2013 the bodgers *cough  cough* sorry i mean fibreglass still lives on ;D
#265 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 08 July 2013 - 02:44 PM
Haha cheers MATE. ;D it's actually really solid!:P must make it a little more solid! Only used it because the boot has to be sealed from the passenger compartment due to the good ole MSA..:D
#266 steven
steven
  • 1,195 posts
Posted 11 July 2013 - 03:09 PM
looking awesome !
#267 afrance94
afrance94
  • 298 posts
Posted 31 July 2013 - 06:48 PM
have you done much more since the last update? would love to see more  :D
#268 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 02 August 2013 - 06:44 AM
Yes bud:). Bars finished, body's prepped, boots prepped and so is the front end, underside is sealed and in colour!! Just waiting to finish this weekend at pembrey so I can do the pics/crack on with paint!
#269 minimaxie
minimaxie
  • 1,687 posts
Posted 02 August 2013 - 07:09 AM
you mean progress has been made?!...
:o
Edited by minimaxie, 02 August 2013 - 07:10 AM.
#270 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 02 August 2013 - 10:27 PM
Serious progress. ;D.
