How To Move A Red Phone Box?
Posted 29 September 2012 - 04:48 PM
I have been offered a phone box from a MCR member in Stourbridge although I am having trouble on working out how is best to move it.
The easiest way was to get a man with a truck and a hiab to collect and deliver it but due to the distance (Stourbridge to guildford) they wanted in the region of £600.
Considered hiring a 7.5 truck but the problem would be how to load the box with the main problem being it is vertical and the most ideal way to transport it would be to make it horizontal. The box is located at a private address so no use of fork lift etc.. Once the box was horizontal loading would be fairly straight forward.
The boxes can be dismantled but after being built for nearly 60 years, I'm sure it would not come apart without a fight so best transported "whole"
Bear in mind the box weights appox 750kg, is 3ftx3ftx8ft, so big, tall and heavy.
Keen to get the phone box but cant justify spending £600 on getting it moved and conscious of trying not to give the seller the run around.
Help, any suggestions, please?
Thanks Dave
Posted 29 September 2012 - 04:54 PM
Posted 29 September 2012 - 04:55 PM
Huge objects can be moved in this manner, including steel shipping containers with the help of a 5 ton jack! if you were closer, i would show you how easy it is
Posted 29 September 2012 - 05:26 PM
Posted 30 September 2012 - 08:58 AM
Posted 01 October 2012 - 12:20 AM
If the box was laying down, it would be easy to move and lift.
Someone has suggested "back load jobs" which is looking like a good option at the moment.
Posted 01 October 2012 - 02:59 AM
* whistles*
Chris
Edited by CLM, 01 October 2012 - 03:00 AM.
Posted 01 October 2012 - 06:16 AM
That is why you use an A frame, easily made from 2 pieces of 4x4 timber. Have been used for thousands of years for lifting/ lying down incredibly heavy things. Even been suggested for Stonehenge! Just need to make sure you have enough people.Finding a vehicle to carry the weight has not really been the problem. The main problem has been finding a safe way to "lay the box down". Im still not sure about the man handling approach.
Posted 01 October 2012 - 07:23 AM
Posted 01 October 2012 - 07:32 AM
A built up mini front subframe would be ideal to use as a dolly to stay with the theme! Haha
Posted 01 October 2012 - 09:21 AM
Easy.
Ratchet straps work ok as hand winches (although very slow) if you get stuck, I've winched a range rover and a 70's yank muscle car onto steep trailers using 2 ratchet straps and another pair of hands.
Posted 01 October 2012 - 11:50 AM
I have a 1500lb marine whinch which i use on the back of my truck which may be slightly under rated for your phone box but i think that it should be suitable for pulling the phone box onto a back of a truck.
A lad at uni got one delivered but as you say, that came off the back of a Hi-Hab.
You should be able to lean the phone box back with a few hands, onto the back of a flat bed and then winch it up?
What would youe plans be for it? They make excellent shower cubicles!
Posted 01 October 2012 - 11:59 AM
Thanks for the ideas.
Its mum's 60th soon and she has always wanted one. Im not sure why, or what she will do with it. Maybe a small green house but red
Posted 01 October 2012 - 01:32 PM
I reckon, as Yoda says, that a few men would easily be able to rest its centre point on a vans load bay edge and, as the pivot point is half way down the box, much less effort would be needed to fully tip it. Place rollers under the box in the load bay and push. 3 man job :)
Posted 01 October 2012 - 03:36 PM
