This sounds like an ideal fix for those screws that hold the vent ports onto the inner flitches.... the one im doing at the moment had rotted through the top half of both sides and all the remaining screws simply snapped off in the captive nuts.... im thinking rivnuts will be a direct replacement in metric and all i have to do is grind off the old rank captive nuts.
Like you both said, theres a ton of other uses for them.
Regarding the headlight bowls, is there a special rivnut for this, like a plastic shrouded one or would you just use steel or even brass rivnut inserts?
Anyway, sounds superb, im getting one asap, thanks a million for the advice.
Edited by antcole, 24 September 2012 - 06:42 PM.
