Can Anybody Recommend A Good Gasket Seal
Posted 23 September 2012 - 11:59 AM
Posted 23 September 2012 - 12:17 PM
or just oil on paper gaskets if you want.
Posted 23 September 2012 - 12:20 PM
Posted 23 September 2012 - 01:52 PM
Posted 23 September 2012 - 03:52 PM
Posted 23 September 2012 - 07:11 PM
Hylomar is ok but im a real believer in RTV silicone sealants applied to oil free gasket material.
The trick with silicone based sealants is the amount you apply..... a bead or a thick layer on any gasket will ooze out loads at the edges, look untidy and also likely to form little worms of the stuff which blocks waterways and oil sump strainers.... plus if you apply too much sealant on a gasket, its likely to skid out of shape and even split the gasket material, ruining your hard work.
It should be applied so lightly that youre simply wetting the surface of the gasket with the thinnest possible coat. That way you get none oozing out and the imperfections of the joint surfaces will be filled.
Some sealants are better when allowed to cure for a few minutes before assembly, allowing the silicone to become more rubbery.
Even and equal tighening of the bolts helps a lot too.
Ive been cursed for my love of RTV sealants in the past by 'old school' fitters and engineers.... but ive never had a joint leak yet.
Posted 24 September 2012 - 07:03 PM
Posted 10 October 2012 - 09:39 PM
Posted 10 October 2012 - 11:48 PM
Posted 11 October 2012 - 11:04 AM
ok cheersA tiny little bit of RTV on each end where the sump gaskets overlap it is essential, but the main part does not need anything as it is a rubbery compound. However, you can safely run a thin bead of RTV around the outside, in the groove.
Posted 11 October 2012 - 07:06 PM
Posted 11 October 2012 - 07:17 PM
Posted 11 October 2012 - 10:50 PM
Exactly what I do as well. It surely works OK.
Posted 20 October 2012 - 03:41 PM
Out of interest, does anyone ever trim the ends of the half moon seal? I've had to set the seal down with rtv sealant as i had fun and games lowering the block down by hand and getting it lined up ok on the seal without it slipping around. Now i have now set the seal on the gear box housing, i don't think it'll compress evenly.
Posted 21 October 2012 - 01:17 AM
