.... Except after a few days I noticed they were all leaking!!! ..... Not such a bargain after all then!!
So I set about doing a refurb after all!!
.... Now the usual way to do a DIY refurb is to spruce up your old rims by rubbing the fronts down, masking off your tyres and then spraying them with rattle cans!! (like this)
I've never been keen on this method though, mainly because alloys tend to corrode more on the rear side and then the corrosion creeps forward to the front side that you can see. Also old ones tend to have a habit of corroding underneath the tyre, which then causes problems with tyre sealing against the rim, so I'm going to do it properly...ish!!
First thing to do is to find out where each wheel is leaking from, after all it could be a puncture, a poorly seated valve, the valve itself, or it might be the rim itself. Doing this is just like finding a puncture on a bicycle inner tube, just stick it in a bowl of water and look for the bubbles, except you need a much bigger bowl of water!! (I tried using the family bath, but the missus went completely ape about it!!....can't think why!!
A 5 year olds paddling pool therefore comes in handy for this (as does the 5 year old for that matter!!
As suspected this one (and the others) are all leaking from around the rim, meaning there is probably corrosion under there. At this point I can either get handy with a set of tyre levers, maim myself in the process and damage the rims beyond repair, or I can take them all down the local tyre fitters and bung the lads a few quid to remove the tyres for me whilst I pop in the pub down the road and wait!!.... Hmmm now which to choose??
.....So a swift pint later then and the tyres are off...
.....a quick inspection and this seems to be the problem:
.....The rear sides of the wheels are in a bit of a state too!!
So time to get busy with a drill and a wire wool attachment!!
...and 10 minutes later we have this!!
Still a fair bit of corrosion remaining though, so we need to be a little more aggressive here.....
..... and after 5 further minutes with an angle grinder & a flap wheel we have this!!
Now to get busy with the wet & dry paper to get the last of the paint off & smooth it all down (I just love this bit....NOT!!
Edited by AVV IT, 20 September 2012 - 09:12 PM.
