Braided Fuel Line Vs Copper Fuel Line
27 replies to this topic
#16 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 18 September 2012 - 06:27 PM
sorry just realised you said clubman estate, heres the pipe but theres no length
http://www.minispare.../classic/petrol
Trac
https://www.minispar...nks.aspx?1~6~50
Here you go Kappa check out item 16 in the list at the bottom, it states the pipe is 134" long
Thank DKlawson Rubber sleeve and p clips are the way forward then..!!
and thanks for the pic Stu, whats the return pipe for? i thought theres usually only the one pipe?
Trac
If you have an SPI or an MPI you will need a return. I need one because I'm running a Honda VTEC
#17 ace01
ace01
  • 457 posts
Posted 19 September 2012 - 11:22 AM
I'm sure I read somewhere that copper reacts with petrol, no idea if that's all petrol or if it happens quickly enough to be a concern. Plenty of diy car builders use copper.
I have an idea that copper reacts with exhaust gases, which maybe what you have read.
#18 Lucas1988
Lucas1988
  • 408 posts
  • Local Club: Frome Mini Club
Posted 06 January 2018 - 04:25 PM
I had this very dilema a few weeks ago and after ruining the first copper pipe I installed I gave up and went braided. Wasn't too expensive in the end. 8mm feed and 6mm return came to about £30 in total
Out of interest, where did you get this fuel line from, a link would be awesome if you have one.
#19 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 06 January 2018 - 05:31 PM
You do realise that post is from 2012!
#20 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 06 January 2018 - 06:24 PM
Buy it per metre, I fit a length of microbore along the floor
#21 nicklouse
  • 18,574 posts
Posted 06 January 2018 - 07:01 PM
I had this very dilema a few weeks ago and after ruining the first copper pipe I installed I gave up and went braided. Wasn't too expensive in the end. 8mm feed and 6mm return came to about £30 in totalFuellines.jpg
One problem with that is you have no idea what condition it is in over time. If the rubber has perished you can not see it. Been there had leaks.
#22 mikal
mikal
  • 240 posts
Posted 06 January 2018 - 10:18 PM
Australian cars used steel (of some sort, doesn't seem to corrode and my car is from 1967) fuel lines. Wonder why they did that here?
#23 Ethel
  • 25,919 posts
Posted 07 January 2018 - 01:25 AM
Brit Minis were also steel from the factory, pretty sure it was stainless.
#24 nicklouse
  • 18,574 posts
Posted 07 January 2018 - 01:34 AM
will not have been. They rusted.
#25 mikal
mikal
  • 240 posts
Posted 07 January 2018 - 07:24 AM
maybe it's the salt on the road situation you have over there?
#26 minimans
minimans
  • 411 posts
Posted 07 January 2018 - 08:38 AM
Steel fuel lines every time, copper will vibrate and work harden over time then split. braided rubber lines are a disaster waiting to happen, you noticed what modern fuels are doing to rubber hoses? even the ones that are supposed to be compatible! but with them being covered your first clue will be the smell of petrol coming from somewhere....................... Bundy tubing is still available, soft enough to bend and rot resistant. You can even get soft stainless designed for small pipes and bends.
#27 grizzler73
grizzler73
  • 300 posts
Posted 07 January 2018 - 10:23 AM
I used goodridge hardline pipe and fittings, braided looks nice but are vulnerable and anyway you can't see it!
#28 Pete649
Pete649
  • 375 posts
Posted 07 January 2018 - 06:33 PM
Ah. That will be why the link in Tiger99's post does not work then :-)
