Historic Rally Clubman Project
907 replies to this topic
#16 Cooperman
  • 23,568 posts
Posted 17 September 2012 - 06:42 PM
Inside & Outside is best. What I have always done to avoid the side-bin accessability issue is to put 3 mm plates both sides, but only welded the outer ones by both edge-seam and plug welding. Then I used the correct bolt size and number and I've never had any issue with this. In fact, I can't remember any scrutineer looking into the rear bins.
On another part of preparation, the heater pipes pass inside the car and it is a requirement that all pipes carrying hot fluid inside the car are either solid walled or braided metal and are painted red.
#17 keefr22
keefr22
  • 591 posts
Posted 17 September 2012 - 06:45 PM
Great stuff, another rally Clubbie, I shall be avidly watching this one! My son & I have just bought a red one with a similar sort of spec., so I shall be looking out for tips! First thing we have to do on ours is make a lighter dash - found out last week that the previous owner had made it out of 9mm MDF & plywood.....!!
Looking forward to your progress!
Keith
#18 rally1380
rally1380
  • 1,893 posts
Posted 17 September 2012 - 07:45 PM
Keith
Hi Keith.....loving the idea of 9mm MDF.....kinda like a built in wardrobe!!! :D i'm gonna have a tie rack in my dash
There will be plenty more updates soon as my first event is a few weeks away and the rear subframe is still leaning against my beetle (best thing for a beetle!!!) so need to pull my finger out!!!!
I think i read on another thread that you had just bought a rally clubman....great mini to buy in my eyes....heaps more room!!! I do have a roundnose before i upset too many people...especially after 'plate-gate'!!!!
#19 keefr22
keefr22
  • 591 posts
Posted 17 September 2012 - 07:56 PM
We found out how he'd made the dash when the tacho stopped working - when trying to remove it we discovered the instrument panel was a sandwich of plywood glued together with contact glue, therefore it's impossible to remove the instruments!! This is in turn is glued to the full width MDF dash - which we can't fathom out how is held in - it appears to be by the front cage downlegs - which also make it impossible to remove other than by sawing it out....!!! Perhaps he wanted a Morgan?! And yes this is the rally Clubman I mentioned in my intro thread. I've always been a heretic liking Clubbies more than the roundnoses - though I'd be quite happy with one of those too!
Good luck with getting it ready for your first event, my boy & I are aiming for a hillcimb next May as ours & I'm already starting to panic!
#20 rally1380
rally1380
  • 1,893 posts
Posted 23 September 2012 - 08:20 PM
Ok so a little bit of an update on progress....
Have been chasing by backside a little bit as time is getting on and first event is looming.
First up was to seam weld all roll cage plates and get them painted ready for cage to go in. In the pic you will also notice a funny bar going from arch to arch. This isn't my attempt at a crude harness bar (although !!!???), it is my way of pushing the rear legs out so they sit on the arches nicely. Made from a length of box section, some threaded bar, a couple of exhaust clamps and a threaded collar...kinda like a homemade acro prop. A bit overkill for some people but very quick and easy to make and it cost me nothing as i aready had all component parts lying round, so my view was why struggle?
Whilst the welder was out, i set about sorting the exhaust tunnel. I think the car was originally a remote change and has a different profile exhaust tunnel. The previous owner had the gear linkage very low on a bracket which made speed bumps very interesting!!!!! This ain't any good for a rally car so out came the angle grinder and a few carefully aimed chops here and there and the hole was created allowing the rod change linkage to sit higher and away from speed bumps!!
I know it ain't pretty but needs must. A cardboard template, some panel beating and an old door skin later allowed for an acceptable resolution. Although its seam welded, i reckon it could be removed and remote change panel work reinstated should the need arise in the future.
Whilst in the area, i strengthened the handbrake mounts with a bit of 3mm plate....seperate bracket and can be removed if required. The bracket also raises the handbrake lever a bit so it doesn't sit so low.
Finally, i fitted a prototype headling which i've made. The reason for a homemade job rather than an off the shelf option was because i wanted the lining as close to the roofskin as possible because the rollcage hoop sits very close to the roof skin and i didn't want any tears in the lining.
Another plus point for this lining is that you can fit it with all windows in place. Some of you might be wandering why i'm going to the trouble of bothering with a headlining in a rally car...simple reason is in some events you have to have interior trim in place...rear seats, door cards, headlining etc. Plus i weighs next to nothing so no great disadvantage
Hopefully you'll agree, but i think it looks smart...a little bit like a mk1 or 2 headlining.
Let me know what you all think
#21 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 23 September 2012 - 08:44 PM
Well the headlining looks like it would pass a scrutineers check, are you venturing out to do my local event then ?
#22 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 23 September 2012 - 08:59 PM
O_O :gimme: nice headlining!! looks nice and retro. keep up the good work!
#23 rally1380
rally1380
  • 1,893 posts
Posted 23 September 2012 - 09:05 PM
yes, entry form ready to post in morning. I see the Perry clubman is also entered....didn't think they were novices??? Also got a scatter rally next monday for a shakedown....fingers crossed it'll be ready for then, otherwise i'll have to ask the wife very nicely for the keys to her Focus!!! In fact she is sat next to me with her roamer and os map practicing plotting.....at least she is organised.
#24 rally1380
rally1380
  • 1,893 posts
Posted 23 September 2012 - 09:07 PM
cheers brad...actually looks better in the flesh....the stitching through the vinyl and foam gives a more pronounced fluted/ribbed effect....if that makes sense.
#25 minisi35
minisi35
  • 723 posts
Posted 23 September 2012 - 09:26 PM
Well they qualify for novices due to their results, julia is still learning on the maps.
Is your wife getting the hand of the maps refs ?
#26 Alex_B
Alex_B
  • 4,573 posts
Posted 23 September 2012 - 09:50 PM
Loving this thread, may I ask how you did that headlining, 1) looks the dogs danglies and 2) when I had my front and rear screens fitted (I wasnt there at the the time) they didnt tuck the headlining into the lip and so at the moment its duct taped up and looks carp so been looking at a headlining that fits like yours above the roof edge. Thanks! and good luck getting ready for and competing!
#27 rally1380
rally1380
  • 1,893 posts
Posted 24 September 2012 - 06:29 AM
She certainly is.....she is very intelligent (i have to say that!!!) so fingers crossed we won't have too many issues. The main head scratching is where to put everything in the car so it is at hand and nice and organised....need a bigger car!!!!
#28 rally1380
rally1380
  • 1,893 posts
Posted 24 September 2012 - 06:38 AM
I work as a furniture designer/manufacturer so have access to the correct materials and equipment. I may make a few and sell them on here to try and fund this project, but it is essentially vinyl with a foam backing sewn through with an industrial sewing machine. Then glued up onto roof skin. Sounds simple, but sewing the lines in the centre was very difficult and making sure the lines are square to the car also tricky.
In theory you could have any design you want....squares, diamonds, lines font to back etc etc etc...even dare i say it a mini logo?
You could buy any fabric/vinyl and glue it up. I was considering a carpet type material but wanted a more retro vibe.
#29 minispaniard
minispaniard
  • 899 posts
  • Local Club: Essex Mini Club, CMC.
Posted 24 September 2012 - 04:41 PM
Funny you say that!!
We did our first 12 car rally of the seaon last week. Mini had blown yet another headgasket so we had to do it with the Focus, my wife is my navigator too... Definitely much more room in the Focus to play with the maps...
She's still a Beginner having only done three other events, with Chelmsford MC Beginners get the route 15 minutes before due start time. Only 2 fails this time, that's a big improvement from our last 12 rally in the Mini!!!
Headlining looks great!
#30 F1L8EY
F1L8EY
  • 600 posts
Posted 24 September 2012 - 07:57 PM
looking good... I also like the fit of the Headlining...
im sure if you made a couple they would sell :thumbsup:
Good luck with the build,,, keep it up!
