12" Pioneer Sub And Vibe Slick A3 Amp
1 reply to this topic
#1 mike.
mike.
  • 6,176 posts
Posted 12 September 2012 - 12:18 PM
For sale 2 pieces of ICE equipment I'm no longer in need of.
First is a 12" pioneer sub and box. I'm unsure of the exact specs of this although I know its around 400w RMS and sounds great run off a decent amp. The box is also an ideal shape/size for a mini's boot.
I'm after £30 for this, collected from Manchester as it'll cost too much to post. Could also deliver within reason for petrol money.
Next is a Vibe slick A3 amp. This is a great amp which has had very little use.
Its 4 channel so good for a full ICE install, and the channels can of course be bridged to run subs at 325W RMS. So ideal to power a set of components and a sub which is what I planned to do with it.
Tech specs off vibe site:
Vibe SLICK A3 Specifications :
  • Type 4/3/2 Channel
  • Class AB
  • Height 65mm
  • Width 475mm
  • Depth 245mm
  • RMS @ 4 Ohm Stereo 4 x 100w
  • RMS @ 2 Ohm Stereo 4 x 160w
  • RMS @ 4 Ohm Mono 2 x 325w
  • RMS @ 2 Ohm Mono -
  • RMS @ 1 Ohm Mono -
  • Max Power 1300w
  • Frequency Response 20 Hz - 20Khz
  • SNR 90 db
  • THD 0.80%
  • Bass Boost 0-24db
  • HPF 50-1Khz
  • LPF 30-300Hz
  • Input mode 2 or 2 Channel
  • Subsonic filter -
  • Remote control Optional
  • Line out -
  • Phase switch -
  • Low level input 0.2 - 6v
  • High level input 0.4 - 12v
Only downside is that the end caps are missing, which didn't bother me too much. Replacement caps can be found occasionally on ebay and may be available direct from Vibe too.
I'm after £45 for this collected from Manchester, if you'd like it posting it'll be £15 as its quite bulky and i'd want to post it insured too.
Any questions PM me.
#2 mike.
mike.
  • 6,176 posts
Posted 17 September 2012 - 10:21 PM
£50 posted for the amp
