Clubman Van Vvc Conversion
#46
Posted 30 October 2012 - 05:56 PM
I've got cylinder 1=150 psi
2=80 psi
3=150psi
4=80psi
Any ideas before I pull the head off?????
#47
Posted 30 October 2012 - 05:58 PM
#48
Posted 30 October 2012 - 10:47 PM
#49
Posted 01 November 2012 - 09:28 PM
#50
Posted 03 November 2012 - 10:27 PM
New engine purchased from a Mgf low milage and 1 lady owner from new,
Had cambelt replaced,new clutch,and up rated head gasket,hopefully this one will run when it arrives
Fingers crossed
#51
Posted 05 November 2012 - 07:01 PM
pulled the head in bits, re set the cams/plunger, nightmare but job done,
time to re build and see if she runs,
back up engine still on its way though,
also purchased a mini maximiser WON kit with 50hp nozzle
im sure that will be fun when installed!!
#52
Posted 14 November 2012 - 08:43 AM
#53
Posted 26 November 2012 - 05:22 PM
the gearbox has the starter at the top of the engine,so ive pulled the box off to put my box on with the starter at the front,
the flywheel and clutch are different,mine is smaller than the mgf one so im having to change the flywheel,clutch and pressure plate,
what crank sensor should i have as i have mems2 ecu which i presume goes with the mgf lump,
im thinking my old lump which im having problems with could have been down to the wrong crank sensor!!!
anybody shed any light on this?
#54
Posted 26 November 2012 - 05:44 PM
They don't run if faulty What issues were you having with the old engine?
Edited by charie t, 26 November 2012 - 05:52 PM.
#55
Posted 26 November 2012 - 07:07 PM
the other engine just wouldnt fire up,
found out compression was down,
replaced the vvc soleniod housing as old one had been blocked up
reset cams,
changed head gasket
re built and still the same,low compression on 2-3 port
so decided to ditch that lump and get another one,
on with changing the gear box and the flywheels are different so pulled them both off and counted up the holes for the crank pickup and both the same so i guess the smaller flywheel and clutch etc should be ok?
#56
Posted 26 November 2012 - 07:54 PM
Pressumably it is the wfm1972 flywheel?
Edited by charie t, 26 November 2012 - 08:40 PM.
#57
Posted 26 November 2012 - 08:00 PM
yes r65 box and flywheel
is this good or bad?
#58
Posted 26 November 2012 - 08:06 PM
Its the flywheel needed thats all
Sounds good
#59
Posted 26 November 2012 - 08:11 PM
ive had nothing but trouble with this old engine and started to loose the will to live!!
so hoping the new one proves good and runs,
#60
Posted 26 November 2012 - 08:41 PM
