However I personally havent seen one as a engine/gearbox combo so I thought I would use my old A+ 998 block and box.
What do you think ? I have access to a larger 60 X 40 cm sheet of tempered glass also.
I quite like the way you can look down the bores into the gearbox, so I was thinking about placing a couple of LED's in the box to illuminate it all. Or should I make too seperate tables, one from the block and one from the box ?
If I keep it together, should I bolt on the transfer case ? Mabey an old dizzy. I like to see the mechanical items that make the engine work but dont want to go over board.
By the way this is just a mock up. And the glass is clean, its just the reflection. Also what could I use to secure the glass in place ? I would like to keep the engine number tag in place, so it would have to be raised. I dont want to use those white double sided sticky pads though.
Any opinions
Elliott
Edited by MiniElliott, 06 September 2012 - 12:25 PM.
