I have removed the air conditioner on my japan spec SPI 1.3 mayfair (1995) and was wondering if I should do anything with the 2 wires from a/c wiring to engine ECU. Red/white & green/white wires, not sure what they do, the a/c system wiring isn't in my workshop manual. Probably idle up or fan or similar feeds. Anyone else done this?
A/c Removal
peter-b
, Sep 05 2012 03:56 AM
5 replies to this topic
Posted 05 September 2012 - 03:56 AM
Posted 05 September 2012 - 01:39 PM
Assuming that the wiring is similar to the 1997 Japanese Mini (page 24 of the aatached PDF link) the red/white is for the compressor clutch relay and condenser fan relay The green/white for the dual pressure switch. The dual pressure switch signal is probably what tells the ECU to idle up when the compressor is engaged. I know that with the SP ACR connected to mine I can turn on and off the condenser fan.
http://www.theminifo...attach_id=68240
I assume that if you leave them alone you should be ok. And hell no! I am not removing the A/C system. I just put it all back together after after 6 months of being apart due to a broken diff.
Posted 06 September 2012 - 01:39 AM
I've removed them from mine and have had no issues.
Posted 06 September 2012 - 08:22 AM
Bloody ripper, thanks xrocketengineer, I'll keep the diagram on file. Although I'm in tropical Queensland Australia, I still recon A/C's not needed in a mini so I'm flogging it off on ebay, to buy more goodies from minispares.........yeah!
This is mini number 11, and probably the last, so it's gotta be just right. When I work out the picture thingo (old usless git) I'll post some picts up.
Posted 23 September 2012 - 12:48 AM
@xrocketengineer
That electrical diagram you linked is tops! . . . It says its for 1997 onwards . . . do you happen to have a 93 Jap Spec Mayfair Diagram in your files?
Also @Peter-B , Hello, I live in Brisbane and also want to remove my A/C and all the parts, do you know of any instrusctionals around the web that might help me out. ? Are you in Brisbane/ want to meet up one day to chat minis, A/C removal ?
Thanks Z
Thanks Z
Posted 23 September 2012 - 02:11 PM
@xrocketengineer
Thanks Z
I have a 1994 Japanese Cooper with a/c. I have not been able to find any information on the a/c system other than part numbers that you can get from Minimania, Minispares and Somerford.
