I have searched through similar topics and feel like ive tried most things suggested!
I have an austin mini 1985 , 998cc all standard!
untill recently it has been running fine. The car starts fine as it always does but when i accelerate the car misfires and either stalls or very nearly stalls.. I can overcome this by either holding my foot down or accelerating very gradually to keep the misfire to a minimum.... this happens until i am in at least 3rd gear and even then the car lacks power until the revs are high again. when stationary regardless of how long the car has been running if the accelerator is pressed and then let off completely the car very nearly stalls and idles very rough.. After reading other posts these are the things i have done.. none of which have made any difference
- Distributor cap cleaned and all connectors checked .. all fine
- plugs and leads all fine, plug gaps checked
- points checked and fine
- timming seems correct
- vaccum hose checked and fine
- dashpot oil level checked
- condenser should be fine as new but havent tried a new one... ? worth it ?
I have also noticed the fuel pump ticks for a while after the engine stops.. longer than i have noticed before... maybe this is normal but surely a sign that the pump is working
any suggestions for my next step would be greatly recieved!!
