And somewhere to spray it, spraying 2k outside is an enviromental hazard and you can be prosecuted for it. It's hardly the most subtle smell in the world either.
Plus you would also preferably want the place you spray heated to avoid leaving you with a soft paint while driving your car for weeks after (although the ripple effect can be fun).
If you're spraying inside, with a heater then you'll also want some form of extraction. While the effects of 2k are cumulative there's no real reason to try and compound the risk by locking yourself in a box with it.
5L of 2k plus thinner and hardener will cost you at least 4 times that of 1k, before any extra ancilleries. That also assumes you have a hvlp kit or compressor and gun.
2k is no longer (in the UK) supposed to be sold for automotive painting purposes.
There's extensive proof that 1k systems last for at least 5 years without difficulty on a daily drive. Many people don't even own a car that long.
If you are unpractised in spraying, there's a good chance you're unpractised in sanding too. Aside from the fact that the thicker the paint the slower it dries, if you start hamfistedly sanding back any paint you'll end up with no paint and have to start again.
In the case of 2k this usually means the whole panel as blending is hard and definitely not a beginners job.
1k systems don't 'need' a clear coat. That wasn't the question or reasoning for the OP's question.
Nice as your marginally incomprehensible post was, it's not really relevent in any way.
Steering back on topic though...
Spoke to a nice lass from Dulux today, she told me that none of their clear systems are really designed for use with the exterior paints.
They offer a yacht varnish, high gloss finish and works with their high gloss so should be fine with rusto also.
She did say though that there's a chance of clouding of the finish (happens with clear coats sometimes) and it won't offer improved durability over the weathershield product which is good for 8-10years as an exterior covering.
It's also completely compatible with the trade high gloss, so I might get a pot myself and see how they compare.
