Changing Front Indicator Lens To Amber - Mpi
9 replies to this topic
#1 Driezzie
Driezzie
  • 662 posts
Posted 22 August 2012 - 01:32 PM
Hi,
How can I remove the clear lens from the black holder ?
I need that black holder to keep the indicator bulb in place, want to go for a more old school look. I think it's glued or something and you can't buy it seperate ?
Attached File  IMG_0885.JPG   29.83K   15 downloads
Kind regards
Edited by Driezzie, 22 August 2012 - 01:32 PM.
#2 miniman retford
miniman retford
  • 3,553 posts
Posted 22 August 2012 - 02:07 PM
There should be two screws through the lens holding in on ?
#3 Driezzie
Driezzie
  • 662 posts
Posted 22 August 2012 - 02:17 PM
yes but they are only for holding the lens with holder in place to the body of the mini. The black holder and the lens seem to be glued together ?
#4 miniman retford
miniman retford
  • 3,553 posts
Posted 22 August 2012 - 03:13 PM
Didnt realise that, shows how much i've looked at mine lol
#5 bcjames
bcjames
  • 2,728 posts
Posted 22 August 2012 - 03:41 PM
Mine just unscrewed and pulled off.
#6 miniman retford
miniman retford
  • 3,553 posts
Posted 22 August 2012 - 03:56 PM
Thinking they must come apart to change the bulb.
#7 jamesmpi
jamesmpi
  • 1,940 posts
Posted 22 August 2012 - 05:16 PM
Yes the lens should separate from the holder. I bet someone has glued it to stop water getting in
#8 Driezzie
Driezzie
  • 662 posts
Posted 22 August 2012 - 07:05 PM
According to Tom of Minisport you buy the plugged ones for MPI as a set, the older ones are just wired directly. The lens is connected with the black holder through a clip he says that can't be removed, I don't want to change the plug and get the older wired ones so I was thinking :
A) just smashing the cristal clear lens (you can buy them by the dozen) and glue the oranje one to the black holder (which is the exact same fit by the way).
B) paint the clear ones which a orange light spray but then again that won't last very long I think.
should I smash it / force it to detach ?
ps : I have a late 2000 mpi by the way.
Edited by Driezzie, 22 August 2012 - 07:07 PM.
#9 Miniholic
Miniholic
  • 132 posts
  • Local Club: MCR Yorkshire
Posted 22 August 2012 - 07:17 PM
Try R1minimagic on here, he breaks a lot of MPi car, so may have the lenses you need.
Or, as people usually want to swap the other way you might be able to do a deal with someone, unless you want to hang on to the originals.
#10 Driezzie
Driezzie
  • 662 posts
Posted 30 August 2012 - 04:35 PM
I took a risk and it looks beautiful :D ! Had to use some brutal force to get the original white plastic ones of but I'm glad with the result. Glued them for extra safety and water resistance. Now I have retro indicators with the plug system of the mpi !
Attached File  Fotor.jpg   46.49K   7 downloads
Edited by Driezzie, 30 August 2012 - 04:36 PM.
