Waxstat Carb Or Not ?
Posted 22 August 2012 - 10:24 AM
Any help would be great
Thanks !
Posted 22 August 2012 - 10:32 AM
The choke linkages are different, if you want to swap.
Posted 22 August 2012 - 12:32 PM
So am I right saying that I have a waxstat carb ? And I need to replace it with this ?
Does it actualy make an improvement ? Does it only make a difference only when the engine is really hot or as soon as the engine is running ? And final question is, is it easy to swap over ?
Thanks.
Posted 22 August 2012 - 12:36 PM
Heres the part number GMCCSK52
Edited by crf150, 22 August 2012 - 12:40 PM.
Posted 22 August 2012 - 12:53 PM
http://minispares.co...its/CRK121.aspx <--full rebuild kit.
The conversion is seperate , but you can convert with 2 x 1p coins
Take the bottom off the waxstat unit (3 tabs) pull out the waxstat piece, replace with 2 x 1p coins....refit (its spring loaded so don't lose any parts when opening)
The part on the right you replace with 2 x 1p coins, the part on the left you keep
Edited by lrostoke, 22 August 2012 - 12:56 PM.
Posted 22 August 2012 - 01:31 PM
Posted 22 August 2012 - 01:53 PM
So what are the benefits of doing this compaired with leaving as isDo the conversion that Steve posted pictures of. It is quick and cheap. All you need is a vice, basic hand tools, and a few coins. You will not be sorry.
Would timing or rpm have to be altered ??
Edited by pierres, 22 August 2012 - 01:55 PM.
Posted 22 August 2012 - 01:56 PM
Posted 22 August 2012 - 02:01 PM
Posted 22 August 2012 - 03:04 PM
The waxstat is basically an emmissions / fuel saver ...when the temperature of the engine bay reaches a certain point thewaxstat weakens the mixture
Benefits of removing ...supposedly better for performance having a fixed jet...but to be honest can't say I noticed a difference.
I converted mine because I had a problem with the car cutting out at junctions but only when engine was warm....figured it was the mixture leaning off to much so converted...it solved my problem. for 2p it was worth a try
Posted 22 August 2012 - 03:12 PM
The Wastat was designed with the intention of thermostatically making minor changes to the fuel/air mixture. There are more than a handful of anecdotal complaints that the thermostatic cartridge (the bronze disk in Steve's first picture) actually causes more mixture problems than justify its use for reduced emissions. That is why there is information on the web both about the 2-penny jet conversion and the fixed jet conversion parts (second picture above posted by crf150).
As Steve said, it won't break, for some people it does help with driveability, and no I would not plan on converting back. The capsule is held in place by crimps. Once you pry those open to install the coins I would consider that a final one-way conversion. Multiple prying and re-folding of the material will eventually result in fatigue failure. Convert once and be done.
Posted 09 November 2012 - 11:48 AM
