Plasti Dip
76 replies to this topic
#46 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 08 April 2013 - 04:52 PM
if you need a white base to get the brightness, you can put a couple of coats of white plastidip on 1st (from the little I learned watching the dipmycar youtube vids)
#47 SAL 821X
SAL 821X
  • 1,890 posts
Posted 09 April 2013 - 03:19 PM
Holy fun bags those first pictures where you just sprayed white primer on to unprepped paint made me spit my coffee every where.
Must admit it does look good though.
#48 Joshwa457
Joshwa457
  • 159 posts
Posted 22 April 2013 - 09:45 AM
Ok so, not been on here for a while. Quick update.....
DO NOT PLASTI DIP YOUR CAR! Basically, the sun over the past 8 months has completely and utterly baked the stuff on. It has faded soooo much it looks f'ing awful now! I've tried peeling it, no luck.. I've tried thinners, paint stripper, blowtorches, petrol, you name it, I've tried it. The only way to get it back off now is to carefully grind it off :-( Absolutely gutted.
Do not do this to your mini. You WILL regret it
#49 flamenco
flamenco
  • 210 posts
  • Local Club: Malta Mini Owners Club
Posted 22 April 2013 - 10:07 AM
could it be that the platsi dip has bonded to the primer you applied? Don't forget that plasti dip is meant to be applied over a glossy top coat..
Edited by flamenco, 22 April 2013 - 10:07 AM.
#50 steven
steven
  • 1,195 posts
Posted 22 April 2013 - 10:39 AM
any pictures of the car as it is now ?
#51 seancv1
seancv1
  • 187 posts
Posted 22 April 2013 - 10:50 AM
must admit i think this may have happened looked good for a while though !
#52 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 22 April 2013 - 10:59 AM
I think that must be your problem, the cars that they show on youtube have been done in a pretty hot climate and they don't seem to have any issues removing it. 1 bit they did mention was if the coating isn't thick enough, then it can be hard to remove, but they seemed to be sugesting that it was more it would come off in small bits rather than the 1 big sheet.
#53 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 22 April 2013 - 11:15 AM
I don't think it's fair to discourage others from using it when you didn't use it as instructed.
#54 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 22 April 2013 - 12:02 PM
Accurate. Applied correctly, you would have been fine. Now you need to sand it away and repaint your car which looked brilliant before you did the whole plastidip fiasco.
#55 Joshwa457
Joshwa457
  • 159 posts
Posted 22 April 2013 - 12:06 PM
Well everywhere the sun hasn't hit (under all the trim) is still as good as the day I put it on and peels off no problem.
#56 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 22 April 2013 - 12:29 PM
The fact remains, you applied it to primer which is porous and designed to promote adhesion. It's unfair to discourage others based on this.
#57 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 23 April 2013 - 08:55 AM
What would be a useful test to see if there was an error with the dip or if it was down to the primer woudl be if you have any left and a good painted spare panel would be to give that the same number of coats, leave it out in the sun for the same amount of time and then see if it does the same or comes off properly.
#58 waddle
waddle
  • 536 posts
Posted 24 April 2013 - 01:28 AM
it comes off primer,ellegadly, theres a video of it on there website
#59 waddle
waddle
  • 536 posts
Posted 24 April 2013 - 01:29 AM
also where did you buy your kit from?
#60 Joshwa457
Joshwa457
  • 159 posts
Posted 24 April 2013 - 05:33 PM
It's does come off primer that's what I was saying. Underneath the bumpers, headlight ring etc when the sun don't shine, it peels off perfect. It's just where the sun has hit it's baked it on.
Not sure where I bought the kit.... But I have a feeling it was straight from plastidip uk
