Automatic, 'slipping' During Gear Change
Posted 21 August 2012 - 02:41 PM
I have an 89 mini Mayfair it has recently developed a problem with the gear change. It appears to slip, juddering / high pitched noise when changing up the box. If you back off it will engage and then drives normally or accelerate very gently it does not happen. Does anyone have any knowledge of this and how to fix it?
Thanks in advance
Ian
Posted 21 August 2012 - 03:24 PM
What type are you using?
Posted 21 August 2012 - 03:45 PM
Is it true that the gearbox uses oil from the engine? are you referring to engine oil?
Posted 21 August 2012 - 03:48 PM
Posted 21 August 2012 - 04:05 PM
Posted 21 August 2012 - 04:07 PM
Posted 22 August 2012 - 04:00 PM
Posted 22 August 2012 - 04:12 PM
Is it only slipping going up the gears or say if your driving along, Put your foot down does it slip ?
Also does the slipping occur of you drive it without warning the engine up ?
I run a 998 auto. I have to say the gearbox profers 10w40 oil (with regular changes)
20 w 50 seems to be a bit harsher on the clutch plates.
Posted 22 August 2012 - 07:14 PM
Thanks for the oil advice
Hope its not a full engine / box change I really like the auto and dont really want to change to a manual box..
Posted 27 August 2012 - 11:45 AM
On mine I had a similar problem when selecting reverse you'd select it then wait literally 2 seconds & then it would engage or ingaging instantly with a rev. A quick adjustment of the gear selector cable solved this for me
Posted 28 August 2012 - 07:45 PM
Posted 29 August 2012 - 04:07 PM
Glad to see another auto lover :)
Sorry not to hijack but helpful people with auto's are few and far between, but I have the exact same problem. What did you do!
Also just a suggestion do a couple of oil changes in a row to flush out the oilways and clean it and check the kickdown lever (dont know exactly what the correct position is but fiddling seems to do something)
