Knocking When Letting Off Throttle
#16
Posted 28 August 2012 - 08:58 PM
Good it possibly be the engine mount on that side has failed?
The bottom rear subframe mount is prone to fail also ( if rubber ), and or the floor cracking if solid mounts were fitted ( happened to me...causing a "knock" )
#17
Posted 28 August 2012 - 09:19 PM
Also check that the master cylinder bolts are tight, so the plate does not move.
#18
Posted 28 August 2012 - 10:48 PM
#19
Posted 30 August 2012 - 08:26 PM
I have found the cause of my knocking sound.
Mine was when accelerating hard and letting off the accelerator quickly.
Silly as it sounds, it was just the exhaust downpipe (where it is 2 pipes not the main manifold) clunking against a bracket on the engine.
It has actually dented the exhaust where it has been pushing against the bracket.
I just bent the downpipe away from the bracket with a crowbar and thats sorted it.
I plan to edit this post in the next few days to upload a photo of where it was catching so others can rule this out.
#20
Posted 30 August 2012 - 09:01 PM
No doubt your picture will make it clearer. It may be correct, but it just sounds a bit odd.
#21
Posted 30 August 2012 - 09:33 PM
I've run an LCB for the last six years without it being supported at the diff.
Never had a crack or any other issue with it. I do of course have a good strap at the rear and in the middle to allow for movement.
#22
Posted 30 August 2012 - 10:13 PM
The Somerford Mini web site shows various uprated manifolds, and they all have the lower bracket.
http://www.somerford...age=page&id=180
#23
Posted 30 August 2012 - 11:34 PM
I think the important thing is the "give" in the rubber hangers
#24
Posted 31 August 2012 - 06:24 AM
The exhaust system is an "inherited" one from a previous owner. It looks cobbled together with masses of jointing paste everywhere.
As far as I could see, there is no support for the exhaust at the manifold end. There is a rubber hanger about half way along the full system and the rubber "donut" attached to the rear subframe.
I am assuming that the torque movement of the engine will probably bend it back with time and the knock will return.
Hopefully, I can get a new exhaust system by then!
As I say, I will upload a photo.
#25
Posted 02 September 2012 - 07:31 PM
Photo below.
New LCB acquired at Minifest today so I can seal it all properly.
I could just attach a clamp where its supposed to be but the system is blowing so badly that I want to sort it all out.
Thanks to all who pointed me in the right direction. I am not mechanically minded (with a mini
#26
Posted 02 September 2012 - 07:45 PM
#27
Posted 03 September 2012 - 11:13 AM
#28
Posted 03 September 2012 - 06:01 PM
Hopefully the MOT won't cost me too much!!
Jake
#29
Posted 03 September 2012 - 10:16 PM
As a newbie, I ended up buying a carb LCB rather than an SPi / MPi one (with the lambda sensor recess).
I only noticed after angle grinding the downpipes off the old LCB as it had been welded together.
I plan to cut out a hole and weld a nut in place which matches the lambda sensor thread and mount it in that.
We live and learn eh!
#30
Posted 03 September 2012 - 10:41 PM
Normally most of the free movement will be at the passenger side (true on left hand drive too, I mean the non-driver side in each case), and it is caused by a simple, inexpensive nylon bush which supports that end of the rack, and can be relatively easily changed. See the Haynes manual for the details.
