Edited by dave-88_123, 19 August 2012 - 08:50 PM.
My Repairs And Smoothing
#16
Posted 19 August 2012 - 08:46 PM
#17
Posted 20 August 2012 - 12:33 AM
As other people have said though filler sinks, cracks, falls out and is in general a horrible thing to use. That said when I was younger (many years go) i smoothed my boot with filler, I must have used about 15 kilos of the stuff and that is how I learnt my lesson
Filler should be used in tiny tiny amounts, I now use it as an absolute last resort and avoid it at all costs.
You may not have any problems with this for weeks, maybe even months and if it does go, you already have some skills to develop.
Well done for getting your hands in there, so many people are not keen to do these sorts of things!
#18
Posted 21 August 2012 - 10:18 AM
As far as the standard of work goes I would say well done.
Thanks Aprechiate the complement
#19
Posted 21 August 2012 - 10:34 AM
to smoothe weld then bog , to seal as said hard drying flexi sealer .
and whos the person that said you have to remove the paint befor filler ? need to find a better scorce for your info
#20
Posted 21 August 2012 - 11:20 AM
#21
Posted 21 August 2012 - 11:22 AM
as said . no point putting bog over rust . or treated rust . its just going to come back .
Right ok as ive said im only just starting, besides its my run around im not planning on making some 100% perfect show car.the cars strucutaly sound dont see the point in welding up a tiny seam, i sanded the wing area down so that i can see the damage and give somthing for the filier to stick to like in most repairs involving filler.
#22
Posted 21 August 2012 - 12:51 PM
#23
Posted 21 August 2012 - 07:15 PM
if its 1k paint them im all for removing it .. if its 2k there not reason why you have to remove it bog will stick to it no problem . and you have a layer to stop moisture getting at the steel .. apart from getting rid od rust thats there
#24
Posted 21 August 2012 - 07:30 PM
Firstly I'd rough up, remove paint and rust with a sanding pad on a grinder. Next mix up p38 and p40 together in equal amounts and then add the harder. Thus giving you a fibre paste and filler combo that won't crack and is sandable. Then normal filler, primer and paint to finish.
