How To Change Gear Selector Oil Seal (With Photos)
37 replies to this topic
#16 rotherham
rotherham
  • 198 posts
Posted 26 August 2012 - 10:20 PM
Good guide I'm gunna do this while the engines out
#17 miniallsort
miniallsort
  • 4,723 posts
Posted 27 August 2012 - 12:09 PM
nice guide mate i fitted 2 seals on mine yesterday
#18 joecefnhedog
joecefnhedog
  • 45 posts
Posted 17 February 2014 - 11:38 PM
so do you have to drain the oil out to refit a metal and rubber seal? as i only recently changed my oil >_<  thanks
#19 Gremlin
Gremlin
  • 2,142 posts
Posted 17 February 2014 - 11:47 PM
Drain it into a clean tray?
#20 joecefnhedog
joecefnhedog
  • 45 posts
Posted 18 February 2014 - 01:10 AM
ok, so it will leak if i disconnect the selector and remove the seals? sorry i'm new to this. thanks
#21 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 18 February 2014 - 10:28 AM
yes it will leak... have a clean recepticle of approx 5 litres handy
#22 A-Cell
A-Cell
  • 1,610 posts
Posted 18 February 2014 - 11:20 AM
...also advisable to fit a new roll pin at the same time.
#23 finch661
finch661
  • 2,339 posts
Posted 17 March 2014 - 08:21 AM
thanks for the guide, helped a lot at the weekend. I have removed the gear selector pins before, but this was the first time i bout the correct tool. cant stress enough on using the propper tool, mine came out in about 3 hits of the hammer!
to get the old seal out, i used a thick self tapping screw and screwed it inbetween the selector rod and the seal (instead of drilling a hole), it just popped out. To put the new seal in, i found that i couldnt get enough clearance to use a socket and hammer, so i used the roll pin tool and tapped it into place!
#24 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 17 March 2014 - 08:46 AM
I know oil may be expensive but I wouldn't ever bother doing that.
#25 Thilemann
Thilemann
  • 45 posts
Posted 17 March 2014 - 09:36 AM
Great guide. And damn. After reading this i just realized i forgot to put the long rubber thing on, after i changed the seal. I'm doing a rebuild, and had to put gear selector back on quickly, because i had to remove it from the lift. So had to take it out of gear. lol.
#26 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 March 2014 - 10:28 AM
  I would not say thats a great way to pull the seal.  If the screw scratches or nicks the shaft it will never seal again.  You should put a screw straight into the seal itself or use a pick, running a screw against the shaft may lead to damage.  So the screw must be small enough to fit into the annular space between the shaft and housing without touching either surface.
#27 finch661
finch661
  • 2,339 posts
Posted 17 March 2014 - 10:58 AM
i would have though that the rubber seal would give in before the steel (the selector)? there was no damage to the selector when the seal was removed.
#28 Dusky
Dusky
  • 5,322 posts
Posted 17 March 2014 - 08:30 PM
My casing is damaged here, any ways to fix it?
I think that fitting 2 seals would cure the poroblem ( the damage is only 3 mm deep orso, but I have the anti leak thing fitted atm.
If I would be sure that fitting 2 seals would work I 'd get the alluminium piece out..
Opinions? ;)
#29 Dusky
Dusky
  • 5,322 posts
Posted 18 March 2014 - 05:35 PM
or is this casing sold.somwhere?
#30 moonet1
moonet1
    Starting My Mini Up
  • 1 posts
Posted 07 July 2014 - 06:49 PM
Thanks! Great Topic which came in very useful this weekend when I changed the oil seal on my British open Classic. Check out the photos of what the previous owner did to the alloy bush behind the seal. No wonder it leaked!
