Welding The Rear Subframe
Posted 15 August 2012 - 10:29 PM
I have read conflicting information some people say it's OK to weld but others say the subframes cannot be repaired and will fail the MOT automatically.
Does anyone have a definative answer on whether welding is allowed, only I don't want to take the trouble repairing, preping, painting, refitting etc for it to fail when I come to MOT it.
Posted 15 August 2012 - 10:49 PM
Posted 15 August 2012 - 10:52 PM
Posted 15 August 2012 - 11:29 PM
Posted 16 August 2012 - 07:52 AM
Posted 16 August 2012 - 05:42 PM
Remember that the side members of the subframe, the usual things to rust, do carry very high tensile loads as you go over bumps, due to the 5 to 1 lever ratio of the radius arm, while the main crossmember does carry a fair bit of bending load. Many years ago, subframe failures were commonplace, and it was almost always a side member that failed. You do need high quality welding, definitely not gassless. Thinning of the lower side of the side members, or patches badly welded in at the low point, where wet mud collects, is not good.
You also need to weld most non-genuine subframes before fitting, because the (Chinese?) manufacturers have usually skimped on the spot welds, and they are known to be fewer than Rover's design calculations said were necessary for safety. A neat, tidy seam weld around the main joints is unlikely to be spotted by the MOT tester, who would not know whether it was original or not once it is painted.
Posted 16 August 2012 - 07:02 PM
Looks like butt welding in a repair then grinding flush is the way to go then. One of the holes is on the top of the frame where it joins the main crossmember, so wont be visible anyway. I think this area may have been where it was originally spotwelded and the other is in the same place but on the bottom on the opposite side of the crossmember. The rest of the frame is solid with no thin or weak points from what I can tell, it is genuine (stamped MOWOG) I will try to put a photo up later.
It's not like it's failed the MOT and I'm taking it back to be retested so the tester will know it's the same frame so it's obvious it's been repaired. So as long as I make it invisible I reckon I should be ok. I'll be giving it a good paint with POR15 as I don't want to it rust, but don't plan on over doing it on paint and underseal so hopefully it wont draw too much attention to it.
Posted 17 August 2012 - 06:22 AM
Posted 17 August 2012 - 03:14 PM
Posted 17 August 2012 - 03:30 PM
Posted 17 August 2012 - 04:46 PM
It certainly does. £350+ for a new heritage was the cheapest I could find!The price of new frames now makes a welded repair very attractive indeed.
Where it needs the patch
Posted 17 August 2012 - 05:00 PM
Posted 17 August 2012 - 05:35 PM
Good idea, thanksGet it sand blasted. Best £30 I've ever spent. Paint stuck to it like poo on a blanket
Posted 17 August 2012 - 05:38 PM
I am slightly concerned about repairing that area, where the side member overlaps the crossmember, because there will be rust between the surfaces, and some unknown about of thinning. I would suggest that the overlap needs to be completely removed, and a bit beyond, to clean it up properly, and a larger patch than envisaged will then be required. It will not actually take much longer to do. Seam weld right across the width of the side member, and be sure to plug weld where the spots were, and seam around the end again.
The metal should be thick enough to weld easily, if it is clean.
Posted 17 August 2012 - 06:11 PM
The non-genuine one on the 25 has lasted 7 years and picked up another new one at mitp for 160. I know about the crap of non-genuine frames, but comparing this new one and the old the new does seam to be welded better. Besides, whats better a rotten genuine frame or a solid non-genuine one?The price of new frames now makes a welded repair very attractive indeed.
Plus I personally can't see the hype in powder coating a rear subframe thinking it won't rot, it will. The only way to stop the dreaded rot is to fill all the nooks, crannies and box sections with waxoil, Something powder coating never will.
