Oil Leaking From Dash Pot.
Posted 14 August 2012 - 08:31 PM
So the question is Why is it doing this and how do I stop it?
Posted 14 August 2012 - 08:56 PM
Posted 14 August 2012 - 08:57 PM
Posted 14 August 2012 - 09:07 PM
Posted 14 August 2012 - 09:10 PM
Posted 14 August 2012 - 09:16 PM
Posted 15 August 2012 - 02:06 AM
See the picture and note the level of oil and where the oil is.
http://www.sucarb.co...tail.aspx?id=93
Read section #4, see figure 6b
http://www.sucarb.co...tail.aspx?id=73
If the innermost steel tube is unbroken there is no path for the oil to leak out of the dashpot/damper. A very common mistake is to misinterpret what "full" means. If you fill the entire center of the carb up with oil (right up to the threads where the dashpot screws in) then the oil will flow down between the innermost tube and the boss that guides it. The oil then finds its way down into the inside of the piston... and drips out of the two holes at the back of the piston.
Refer to the picture in the first link and stop filling the innermost tube when the oil is about 1/4" below the top of the inner tube.
Posted 15 August 2012 - 10:52 AM
I decided to take a picture:
Are you sure you are filling the dark centre tube, or the whole thing?
I just cannot see how the centre tube would be leaking it into the bottom of the aluminium housing, it's thick steel in an area that sees limited force
Yes I'm only filling the centre bit mate! And mines a hiff44
Edited by hughzy69, 15 August 2012 - 10:57 AM.
Posted 15 August 2012 - 10:53 AM
Please see the pictures in the links below.
Yes this is what im doing and the oil is just seeping out one of the holes when it tilts forward slightly to locate the needle in the hole
Posted 15 August 2012 - 11:09 AM
Edited by hughzy69, 15 August 2012 - 11:09 AM.
Posted 15 August 2012 - 12:00 PM
Your sanity check is to take a compressed air hose and supply air to the open end (left end as shown in your picture above) of the center tube. If you spray the piston assembly with soapy water (or dunk it in soapy water), bubbles from the compressed air will reveal where any cracks or problems are.
If the compressed air and soapy water reveal a leak path, replace the piston assembly AND the vacuum dome that it works in. The piston and dome are machined as a matched set. While you can sometimes mix components, you shouldn't.
