Monterey Body Kits
Posted 14 August 2012 - 12:53 PM
Cheers everyone
Posted 14 August 2012 - 01:29 PM
Posted 14 August 2012 - 01:55 PM
and more (I don't feel too good)
Posted 14 August 2012 - 02:42 PM
However I must confess to being a bodykit person, but a bodykit is suppose to look like an extension of the existing car, not something glued on if done right.
And if your defiantly after a body kit, remember that most of the time you can mix and match fronts, backs and sides to get the look you want with only minor work needed to join them together.
Posted 14 August 2012 - 03:00 PM
Posted 14 August 2012 - 05:09 PM
Posted 18 August 2012 - 03:12 PM
Posted 18 August 2012 - 03:34 PM
Posted 18 August 2012 - 05:42 PM
Posted 18 August 2012 - 08:17 PM
On a different note if your fitting that wing on the back you will notice in that link the green car has a wider front splitter. I've found recently if fitting any sort of rear aerodynamic modification to the back you need to counter it at the front or your find the front goes light at speed. They sell the kit with a narrow splitter, but the green car owner made it wider which indicates the narrow version doesn't work so well. It's not hard to fix, your best bet would be to take off the bottom lip and add a separate flat panel, as that bottom lip also angles upwards in the pics of the purple one which is not so good either as it wants to be horizontal to the ground of angled down a degree or two. Also fitting a separate flat panel you could make it adjustable then if you find the front is light at speed, you can move the angle down a degree or two to increases frontal downforce.
Sorry again if I was a bit harsh
Posted 18 August 2012 - 09:15 PM
Posted 19 August 2012 - 12:52 AM
Posted 21 August 2012 - 08:17 AM
best of luck with your purchase!
Posted 25 August 2012 - 07:12 PM
Edited by Project79, 25 August 2012 - 07:14 PM.
Posted 25 August 2012 - 07:25 PM
Not sure what you're planning to do, and this is just me, but thought where the bodykit flares out behind the front wheel, a strip of mesh or some sort of grill would look good in there, instead of just nothing. Up to you but I have a cnc router and if you fancied putting something in there give me a pm and I can cut something out to fit.
