Dutch Micra-Engined Mini
#16
Posted 09 August 2012 - 07:18 PM
#17
Posted 09 August 2012 - 08:06 PM
Really neat installation, do you have any more pictures of how the subframe gets around the inner wings? I've never seen a subframe design that has support from the top of the suspension towers down to the front support that didn't require removal of the inner wings, would be great to see how you've done it. Hope my project turns out as neat as yours.
i tried to make a picture from under the wheelarch, i will make a better one after the weekend.
the inner wings just fit inside the frame, some modifications on the wing are required with this frame, but nothing major.
#18
Posted 09 August 2012 - 08:09 PM
Edited by MiniNissan, 09 August 2012 - 08:10 PM.
#19
Posted 09 August 2012 - 08:16 PM
#20
Posted 09 August 2012 - 08:22 PM
#21
Posted 11 August 2012 - 06:48 PM
#22
Posted 13 August 2012 - 09:30 AM
I guess the downside is the subframe doesn't offer much protection for the engine in case it does scrape.
Your alternator has me wondering if I could find one to front mount mine but I'm not paying 175 - 510 pounds that Brise quote!
But maybe I can find a smaller one that'll do the job. Suzuki swift seems as though it might be an option... http://www.turbomini...p?p=vt&tid=2995
I originally thought that your engine must be further back than mine (because of the firewall modifications)
but it's clearance on the water pump that determines how far back it can go so it can't be that different.
Bart you've found some different solutions to the conversion problems, great work!
#23
Posted 13 August 2012 - 03:36 PM
Hopefully downsizing my alternator will stop from hanging out the front.
lovely subframe work.
#24
Posted 13 August 2012 - 09:50 PM
#25
Posted 14 August 2012 - 10:04 AM
aldon points dizzy? is that a nissan item or off something else? i want to rin mine on carbs too be alot easier to replace the dizzy i got with a old fashioned manual dizzy! as im unsure what is invovled with the mega jolt system. any light you can shed on your ignition system would be a massive help! also you running a race tank or standard with a inline pump? many thanks luke
The distributor is from the old a-series mini engine. still running breaker points. i had a bush made which has the outside diameter of the nissan distributor hole and an inside diameter of the mini distributor. the i modified the nissan distributor drive to fit on the mini's distributor shaft. there is more info on this in bigchiefs thread. irc someone used a late mini's distributor with electronic ignition. It seems to work fine, but for now i can't really tell you if the advance curves are anywhere near what the nissan motor wants, but there is no detonation or whatsoever throughout the rev range. the fuel tank is just the standard mini item with electronic fuel pump, no extra regulator.
the distributor in place:
fuel tank and pump:
the small plastic inline filter is there, because the tank had been in storage for some time and even though i cleaned it, i just want to be sure no dirt finds its way into the pump/filter.
#26
Posted 14 August 2012 - 10:23 AM
I really like how your subframe doesn't reduce the ride height any, as it's low enough already anyway.
thanks, the subframe is about an inch lower then standard. the lowest point is where the lower tubes meet the subframe. where the bottom arm sits. that is lower then the sump. i was thinking about what you said about protecting it, and i think i can make up a very simple but effective sumpguard on the subframe.
scraping?? haha, i'm used to some scraping now and then, check out my daily driver...
#27
Posted 14 August 2012 - 11:51 AM
These were taken a while ago there's been LOTs of re-enforcement go in and the rails are no longer just tacked on.
Basic idea is that the mini should be able to slide up on those rails, later I'll mount a sump guard to the bottom of the rails as well.
* Any engine conversions in Australia need to be signed off as complying with Aust. Design rules by an engineer. (not the easiest process)
The subframe is almost finished now (sorry no photos) and then hopefully the conversion will move along a bit quicker.
Yeah can see why the kombi might scrape...
Edited by fuzzy-hair-man, 14 August 2012 - 12:06 PM.
#28
Posted 14 August 2012 - 11:53 AM
Edited by fuzzy-hair-man, 14 August 2012 - 11:57 AM.
#29
Posted 14 August 2012 - 06:59 PM
i love to see pictures of the finished frame. What did you do to put some strength back in the rear of the frame? where the diff. sits?
Your engine mount design is almost identical to mine, only much thicker material.
#30
Posted 15 August 2012 - 12:26 AM
The engineer's specs were 6mm x 50mm plate joining the rails to the rear subframe mounts and over the arch between the towers, sort of like in this diagram:
Some of the re-enforcing curiously is the same as recommended in Vizard's white book in the section about rally prepping.
Given the strength in the original subframe it's many times stronger, the weight of the subframe is beginning to worry me a bit. But to some extent I have to do as requested.
Still the engine is significantly lighter and the extra stiffness may help improve handling, it's also a very simple and light weight sumpguard now compared to the original.
by the way I think all of the Australian mini's have solid mounted front subframes, was there a point where rubber mounting subframes was phased in over there? (our last minis were ~78 clubmans)
Off to look at small alternators at the local wreckers...
