Tap And Die Set Recommendation
Posted 30 July 2012 - 08:14 PM
Can anyone recommend a good quality tap and die set to use on my Mini?
I need to re-thread the bolts for on the front hubs to just remove some burrs, so I want to buy a good set that won't break the bank.
Anyone got any ideas?
Thanks,
RodAndTom
Posted 30 July 2012 - 08:15 PM
http://www.machinema...pce-tap-die-set
Posted 30 July 2012 - 08:21 PM
Posted 30 July 2012 - 09:35 PM
Edited by dow62, 30 July 2012 - 09:36 PM.
Posted 31 July 2012 - 02:15 AM
I cannot recommend specific tap and die sets but will suggest you look for the following things. Buy alloy steel taps, not carbon steel. They should have a bright alloy appearance and a ground finish not matte. If you decide to buy taps one at a time, buy plug or taper taps, not bottoming taps.
Posted 02 August 2012 - 09:22 AM
Sound advice. I will look at the options and let you know what I go for.
One question though - any idea how to work out what size you need to clear up existing threads? I am going to be doing the swivel joints on my front hubs and to be honest, I just want to make sure I get a set that can deal with that particular problem right now.
RodAndTom
Posted 02 August 2012 - 11:22 AM
Posted 02 August 2012 - 05:31 PM
Good tool shops such as Buck and Hickman also sell taps and dies, if you are in a hurry, as they may be more expensive than the various suppliers listed above.
Posted 02 August 2012 - 07:25 PM
You mean the ball joints, I would not recommend this just buy a new set.
I didnt mean the ball joints themselves, I meant the thread on the hub that they screw on to. I need to work out what size that is so I can get the right thing. That's what I need help with - apart from trial and error how to you tell if you have metric, imperial or whitworth threads and what size they are?
Thanks,
RodAndTom
Posted 02 August 2012 - 07:37 PM
Posted 02 August 2012 - 07:39 PM
I am confused now. The ball joints are the components on top and bottom of the hub assembly that are secured by the big domed nuts. No tap and die set is going to have that size in them. If you mean the threads on the ENDS of the ball joints, those could be retreaded with a die but it would probably be safer and better to fit new ball joints instead.
There are a negligible number of metric and Whitworth threads on a Mini. Probably 95% of them are going to be imperial (UNF). There are going to be a handful of BA series threads here and there but they are not common. As for determining the size, you need to measure the major diameter of the male thread and then count the number of threads per inch. The major diameter will identify the general size, the pitch of the threads will tell you if the bolt is UNF (fine thread) or UNC (coarse thread). There are online lists that will tell you which thread is fine and which is coarse.
Posted 03 August 2012 - 05:29 PM
It is the thread that the big domed nuts screw on to. Are you really saying that I won't be able to get something that size? So what does that mean? You can only rennovate small threads?
RodAndTom
Posted 03 August 2012 - 06:08 PM
http://www.tapdie.co.../unc__dies.html
Cheaper than i thought but as to their quality??
Posted 03 August 2012 - 06:10 PM
Time to buy new hubs then I think!
Although I will invest in a good quality set as a result of this for general use.
RodAndTom
Posted 03 August 2012 - 08:35 PM
