Mot Mini Failed - Offside Steering Rack Gaiter Split
#16
Posted 20 July 2012 - 07:30 AM
See if the place that's doing the mot can do it and how much they'll charge
#17
Posted 20 July 2012 - 10:52 AM
#18
Posted 20 July 2012 - 03:13 PM
#19
Posted 20 July 2012 - 03:17 PM
If I clicked the steering lock in place would that help ? As I've tried using those mole grips that clamp but still not enough.
Gonna keep soaking it
#20
Posted 20 July 2012 - 03:26 PM
Just make sure you have enough thread engagement in the joint so you don't strip them.
#21
Posted 20 July 2012 - 04:39 PM
#22
Posted 20 July 2012 - 04:43 PM
#23
Posted 20 July 2012 - 04:45 PM
#24
Posted 20 July 2012 - 05:56 PM
I could try cutting it off if all else fails
#25
Posted 22 July 2012 - 10:25 AM
Plenty of penetrating fluid will help and maybe a bit of heat
#26
Posted 22 July 2012 - 10:35 AM
No, he's talking about the locking nut that holds the tracking set! (I Think)
The same thing then - locking 2 nuts is ok if leaves enough room - my suggestion is similar: screwing the end in a blind hole.
#27
Posted 22 July 2012 - 01:05 PM
The ball joint that's being a bugger are they expensive or hard to fit because could try and just get it out and replace ?
#28
Posted 23 July 2012 - 10:59 AM
curse my life haha
Tried jacking the hub up as thought that might break the seal but no, been hitting it with a hammer but no luck
#29
Posted 23 July 2012 - 11:43 AM
Track rod end = GSJ1106
If I still haven't made myself clear enough, put something inside the hollow end of 2. so it stops it screwing on to the rod as far as 1. Pick something that will fall out easily if you want to reuse the rod end.
Though gripping the rod with mole grips is usually sufficient to unscrew the lock nut.
#30
Posted 23 July 2012 - 11:57 AM
Also if you find the ball joint pin spins, use a jack under it to push it all together and hold in tight.
HTH
