The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#886 Minidarren83
Minidarren83
  • 1,207 posts
Posted 06 February 2016 - 10:53 PM
A few changed and additions over winter
New rear seat for the kiddies
And a new t7 heater with an mg resistor pack fitted so I can have 4 speed
The turbo would just not fit even after cutting **** loads out of my front so copied Pete and made this type of manifold
With the engine back in the car I can work out the last but of the manifold
And it now fits inside a standard clubby front just means I need to fix all the holes I cut and repaint
#887 James_eaton_thewholething
  • 1,063 posts
Posted 07 February 2016 - 01:03 AM
have you tested how hot the heater gets as i will be fitting one of these or I'm going to go with the micro heater.
#888 Minidarren83
Minidarren83
  • 1,207 posts
Posted 07 February 2016 - 09:44 PM
No not yet I don't have any water in the system
Bit more done finished the manifold and git the turbo mounted
I ended up welding the flange to the manifold to secure its position before making up the small link piece with a toilet roll tube
A good bit of clearence to the oil filter and the exhaust just goes where it should
#889 lawrence
lawrence
  • 1,341 posts
Posted 08 February 2016 - 07:49 AM
Are you using plumbing pipe for the manifold bud out of curiosity? I remember seeing someone who did on another forum, it came with nice chamfered angles all ready to fill with weld and was about 4/5mm thick
#890 Minidarren83
Minidarren83
  • 1,207 posts
Posted 08 February 2016 - 09:43 AM
They are weld pipe fittings just used to make making bends in large scale pipe easier. The corners have 3mm wall and the tee have 3mm at the ends with 4-5mm on the thicker bits
#891 lawrence
lawrence
  • 1,341 posts
Posted 08 February 2016 - 12:18 PM
Cheers bud. I'll keep an eye out for them if I fancy making a turbo mani for mine
#892 Minidarren83
Minidarren83
  • 1,207 posts
Posted 08 February 2016 - 07:59 PM
You can get them on ebay just type in "weld tee" and "weld elbow"
#893 Minidarren83
Minidarren83
  • 1,207 posts
Posted 11 February 2016 - 08:31 PM
Started on the intercooler pipework
#894 Domeo_Jones
Domeo_Jones
  • 161 posts
  • Local Club: none yet
Posted 11 February 2016 - 11:02 PM
Hello darren! Looking good!! this mg resistor pack...how does it work by the way.
#895 Minidarren83
Minidarren83
  • 1,207 posts
Posted 08 March 2016 - 04:48 AM
I've not updated this thread in a while but it's moved on a long way all I need now is oil feed and return and it's ready to burn up the tyres. It's not been the easiest task squeezing the 1.8 and turbo in a standard clubby front but it fits
I just need to repair the front after my first attempt at getting the turbo in didn't work
New interior to come soon
#896 Minidarren83
Minidarren83
  • 1,207 posts
Posted 11 March 2016 - 03:09 AM
Fresh carpets and finally some door cards
#897 Carlos W
Carlos W
  • 10,115 posts
Posted 11 March 2016 - 08:20 AM
Not sure about the coffee cup mate
#898 Minidarren83
Minidarren83
  • 1,207 posts
Posted 12 March 2016 - 05:18 PM
Fixed that problem 👇
Rear seats fitted with added cup holders so I don't need to drive with coffee between my legs
#899 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 13 March 2016 - 09:03 AM
Fresh carpets and finally some door cards20160310_135146_zpsedv73w3c.jpg20160310_142618_zpsyw65a17v.jpg
Love the dash m8
#900 Minidarren83
Minidarren83
  • 1,207 posts
Posted 08 April 2016 - 12:12 PM
So where do I start....
I pulled the car out of the garage but forgot to close the door and that was the end of that door
Oil feed line made
And fitted
Stripped repaired and reskined the passenger's door
And changed the clutch on the winter car
