The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#76 grahama
grahama
  • 2,442 posts
Posted 02 October 2012 - 08:45 PM
Getting good at this fabrication and patching my man !! the welds look great ground down, very nice.
Graham
#77 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2012 - 05:36 PM
update 2 of this week
so started today with making up one of the two needed patches to the storage bin it was a small piece with two folds on the outside edges once made it was tacked in place
and then fully welded in the penetration was a little dissapointing today it is strong but will need filling to make flush
then it was on to the last part of the bin this one was going to be a pain as it needed a curve putting back in
so i started with a piece of steel
then clamped on my angle iron
and knocked the edge over about half way doing a little at a time
then the lip was trimmed down until the part fitted and then it was tacked in place
and then fully welded making sure i had good penatration was imprtant for this one as i wanted it right the first time and not have to add bits on the underside when grinding
then using a mix of flap disc and 1mm cutting disc on the grinder and air cut off tool it was very carfully ground flush and i was left with this
only one of the welds on top needed flatting off so the inner sill could sit flat on it
after that it was time to trail fit my herritage floor half it was such a nice fit i used a bolt throught the old seat mounting hole and through the new and clamps alont the step edge it was then marked and cut throught both floors to ensure a perfect fit
and here it is all clamped up ready for welding i just need to make up five or so more intergrip things
that should be done tomorrow but i need to prep the floor first filling in all the drain holes and making the inner sill stiffner and being stupid i threw out the old bit of sill with the seatbelt nut on it and the scrap man came today so ill need a new nut and plate before the outer sill goes on
darren
#78 grahama
grahama
  • 2,442 posts
Posted 03 October 2012 - 06:27 PM
As I said yesterday, very nice work, that inside grind down is sooo much better than I ever acheived on mine, well done.
Graham
#79 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2012 - 07:04 PM
cheers graham your praise is always welcome seems you are the only one watching this thread lol more tomorrow
darren
#80 minimikej
minimikej
  • 347 posts
Posted 03 October 2012 - 07:48 PM
Great work!
#81 F1L8EY
F1L8EY
  • 600 posts
Posted 03 October 2012 - 07:59 PM
hes not the only one :shifty:
great build so far keep it coming...
#82 Carlos W
Carlos W
  • 10,114 posts
Posted 03 October 2012 - 08:49 PM
I'm here too! Great work mate!
#83 BenH
BenH
  • 742 posts
  • Local Club: CV1 Minis
Posted 03 October 2012 - 08:55 PM
Im also lurking ! Just had to finish updating mine and scubbing the crap off my face and hands! Everything on yours just seems to fit perfectly, I need to get mine on its side, need to hunt for some cushions/matress!
#84 joezone2001
joezone2001
  • 332 posts
Posted 03 October 2012 - 09:07 PM
I am also watching and lurking. some fantastic work going on here. keep up the good work. Joe
#85 Minidarren83
Minidarren83
  • 1,207 posts
Posted 04 October 2012 - 07:02 PM
update 3 of this week and the last i think
well today i started a little later on the mini and started with making another 4 intergrips so i now have 5 of them and they cost me nothing only scrap from what i have laying around my garage. Once that was done i clamped in the floor half fully and started tacking it all the way along about an inch or so apart i found that tacking in the tunnel part wich was slightly upside down imposible and i will be welding this part from the inside that is almost flat i never want to weld upsidedown
then welded the rear half in fully this is the worst bit for me as i hate cleaning up the long welds i much prefer the smaller patches
and the inside
and then all cleaned off
i see no point in grinding flush as it will be covered in stonechip and carpet anyway. hopefully i will get the front part all cleaned off over the weekend then do the doorstepp edge plug welds and then move on to the boot i can almost see light at the end of the tunel. In other news i had a delivery from smiffys bit most of the nuts and bolts to build up the front subby will be getting the rest for the front and rear next week not fitting any more mild steel to this car it will all be stainless as much as possible
thats all for now cut today short i could not take anymore grinding
darren
#86 MrBounce
MrBounce
  • 2,641 posts
Posted 05 October 2012 - 04:16 PM
Awesome work. It is exactly this sort of thing that gives me inspiration to do more with mine! Well done :gimme:
#87 stretters
stretters
  • 71 posts
  • Local Club: Ipswich MOC, AMC, CMC, MCR.
Posted 05 October 2012 - 05:24 PM
You should try Roloc discs on a mini air grinder or drill - they're awesome. Really fast clean up of the weld pool and fairly quiet to use too!
I started with these as they included the holder atachment.
http://www.ebay.co.u...6#ht_500wt_1054
The 60 grits also come in handy to dress back the spot welds on damaged unwanted panels....
Edited by stretters, 05 October 2012 - 05:27 PM.
#88 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 October 2012 - 08:02 PM
Thanks everyone for the Praise and encouragement over the last couple if days I know I'm doing the car for me but we do document them on here for others to also enjoy and maybe learn a thing or two so it makes it worth it to know people are watching and enjoying it as much as me me cheers fellas
Darren
#89 Minidarren83
Minidarren83
  • 1,207 posts
Posted 12 October 2012 - 07:36 PM
got out in the garage for a couple of hours this week not done much but got the outside fully ground down its by no means smooth but a bit of seam sealer and a healthy layer of stonechip and you will never tell
i also got the doorstep plug welded on they are getting neat now just nice pools of weld easy to grind away
and then seam sealed an old weld that needed doing i used tape on both sides to keep it a neat line sort of lol
thats all for now
darren
#90 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 13 October 2012 - 07:47 AM
That is some bodywork!! The welding is certainly coming along - these plugwelds are lovely. Keep up the grand work
Hugh
