The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#721 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 November 2014 - 03:25 PM
Nice project :)
Cheers nice to see new people taking an interest
#722 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 November 2014 - 08:35 PM
So another hour today and part one of making the standard grill and headlight setup work
Start off with cutting the old crap out and sand all the flanges flat
EED3E1BF-10B3-4DF8-BC74-D02049845AEA_zps
Then see if the whole is the right size for the grill. Looks much better already
24C16D75-4C8E-45AE-B363-9AF9E27F6D34_zps
It needs a little work at the top either making the grill slightly bigger (reads bending it) or cut the front on the bonnet lip pull it down and glass it back up
EB0278E1-F86B-406B-82BA-57F5E0DD3C24_zps
More to come making the light pods
#723 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 November 2014 - 09:51 PM
Much better Darren  :highfive:
Looks really good
#724 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 21 November 2014 - 10:09 PM
As above much better, are you going to add some fiberglass strengtheners between the bonnet and front panel and for mounting the grille?
#725 hoody99
hoody99
  • 699 posts
Posted 22 November 2014 - 11:16 AM
This is what I wanted to do to mine but got a sore head thinking of how to do it and make it look good so just rolled with the way it was using round nose headlight sourounds till I can afford a better front lol
#726 Minidarren83
Minidarren83
  • 1,207 posts
Posted 23 November 2014 - 03:49 PM
So part 2 of the grill saga started by cutting a piece of steel to the size of the grill
C2D87D8D-6480-417E-8313-16F0AFEA99A2_zps
Then welded a strip to the outer edge
E5BC9B90-9641-4741-AC27-ED184A4C192D_zps
And this is will now become the mould for the fibreglass part and give me a headlight panel like this
BD765C93-56FD-4251-BDB3-88E4B4B423E3_zps
#727 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 January 2015 - 03:25 PM
Jesus I've not updated this in a while well I've not touched the car for that time either. But today I went to pick up a diesel box and the bloke couldn't be bothered splitting the box so I took the lot in the boot of the fiesta
03D3D645-D6F3-4892-B881-B262DA982F54_zps
And using my favourite method a good old plank and elbow grease. Engine out and box split stick the engine out for the scrap man
0A722C97-8915-4868-A71D-8938C7096DAA_zps
Then stripped the box down I kept all the bearings as I can't remember what ones I need from the u spec derv box so I'll just compare them all
5EC9ACBF-4A98-4598-B171-43F0F496B90A_zps
I want the car on the road by my birthday in May so I've warned the wife I will be doing something everyday even if it's small
#728 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 January 2015 - 03:26 PM
Got out there today at 8pm after doing dad duty so started by taking the engine out the mini and splitting the box
DF5D74B6-A9E8-4084-8B37-D9BAC557DDEA_zps
Then stripped the box down nice and quick then built all the diesel gears back in the petrol case
4A921F20-2A71-4D57-8FEA-209B6B8DF015_zps
I used the petrol selecter and reverse as they looked to be in better Nick
2C7DC48F-FF3D-47C7-B1B5-5D8AB71E601C_zps
That's todays work just need some gasket sealant then I can put the top half back
#729 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 January 2015 - 03:27 PM
Sticking with the something everyday plan I couldn't get and gasket sealant so made the two headlight pods for my frontend
412C2FC0-033D-4DBE-A47D-998955338407_zps
#730 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 January 2015 - 10:10 PM
Today's uodate
Rebuilt driveshafts with new cv's and recon the brake master
C351128F-F2C3-49C0-9C91-F4A74BDEDE54_zps
Then trim and glass in the headlight pods
EB5D407D-412A-4C55-B17D-90043C1C9E93_zps
Don't worry I won't be posting everyday wouldn't want to bite you with pictures some days there may only be a small amount done so not worth it
#731 alex-95
alex-95
  • 6,024 posts
Posted 05 January 2015 - 10:20 PM
Looks good mate, I think I'm going to have to do the same as you doing stuff in the evenings :lol: The headlamp pods look good.
#732 Minidarren83
Minidarren83
  • 1,207 posts
Posted 12 January 2015 - 02:58 AM
Update from the last few days I've got the box back together back on the motor and back in the car with the hard to reach hoses attached
46E97B6B-6C9A-4408-836B-CBD14761881A_zps
Then fitted the driveshafts and shocks
74CC9A7D-15E0-45F6-AD97-9E45950CFDC4_zps
Although I have a problem I don't seem to have neutral I've got all the others just not neutral
#733 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 January 2015 - 11:09 PM
One step forward two back
Had to remove the engine and strip the box back down this evening turns out I put the 5th gear syncro hub on upside down but all fixed now and I'll put the engine back tomorrow night after work
F42BE72C-4D0F-4230-BC2A-335F0FD9155B_zps
#734 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 January 2015 - 11:10 PM
Uodate from last night
Got the box out back together and back on the engine then back in the car with the shafts then plumbed in my new ebay special radiator and fan. I ordered the cheapest rad I could find and got one of the fletcher ones sent not bad
6B85083F-94D1-4586-9CF3-96C6236649F4_zps
The old bypass inlet on the thermostat housing is it in the positive flow so I bought an ally blanking plug and tapped it as a bleed point
61AF7D05-077E-44AA-83F0-9734ABFAE8B4_zps
And the bottom hose uses standard mini bottom hose to a 90 bend into the cut down metal return pipe to the engine and the two blue connectors you see are inline to the heater hose to the return as a bypass when the heater is off just need a 180 bend in 19mm
B1D02185-D8D2-4C09-9A09-6D8F4703E869_zps
#735 Minidarren83
Minidarren83
  • 1,207 posts
Posted 10 February 2015 - 06:53 PM
I've been plugging away at this little by little I've got handbrake internal battery and brake line along with the fuel so it's ready for the interior to be fitted apart from the dash I've also got the throttle cable and clutch in. I've made my alternator bracket
0AF7CAE5-DB5F-4312-82E7-A293B603DC03_zps
9E26B246-59AE-49FB-8D97-D5B602124EDE_zps
Seems to fit well and straight but only have 20mm travel for adjuster so I'll see how it does
33B985E9-207C-4E5A-B368-D07B49515035_zps
Started reworking the frontend so I can fill in the cutouts I made and fit the tie bars in properly. I've moved it forward about an inch
8BC2FE30-6FE8-4C24-AA67-241C173CC08B_zps
Also got a fitting to finish off my waterworks just the heater to plumb in
9136EA54-D7A7-4482-A329-7E02B9C73C4D_zps
I saw this on another build and thought it was a neat way of doing it so engine electrics run into the car here along with the starter live
C69AAA9F-8CA4-4FD0-91F7-E8B55D570783_zps
Then plumbed in the fuel lines to the engine
2F0CAAF9-DAF4-4811-8D40-A38F1B367256_zps
Slowly ticking things off the list
Cheers Darren
