The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#706 Minidarren83
Minidarren83
  • 1,207 posts
Posted 16 October 2014 - 06:37 AM
Also I've started the flatting process starting with 1200 as there are a few runs in the grey and plenty of peel to take out the moving up to 2000 before a good mopping with Meg's 105 then 205
Impatient sh*te! I'm not giving you a hug if it pulls.
I do happen to have a fair amount of screen tint film if you fancy a practice before you go yourself ;-)
Na it's 2k mate best to get it flatted in the first few days or it will become much harder to do
#707 zeemax89
zeemax89
  • 129 posts
Posted 16 October 2014 - 04:15 PM
UPDATE!!!
first off a few thanks for the kind words
brum,brum,mike its slowly getting there. HughJ i think by the fire is the best place for this time of the year not sure why i put myself throught the cold. Grahama im glad you added the finishing part at the end as with the welder i have its all in the finish for me until i can afford something more reliable. Jasonc dont be jelous its freakin freezing out there lol. Skortchio ha ha i think there could be a thing or two you could teach me lol and finally junky it certainly has come a way since you saw it you and dave are more than welcome over anytime im not at work lol
Anyway now for the update picking up from the last post i was not happy with the panel so started again and added the angles and lips that were needed
not excatly the same but the best i can do with my tools and the grey stuff is seamsealer
then got it clamped and tacked in place
and then fully welded
and then cleaned off although i was not very happy with the finish so ended up putting more blobs and made it look very messy but you will never see it
then i made up this little panel for the rest of the crossmember, first out of card then with flanges bent in
and then clamped spotted and for my first bit of upsidedown wacked up the power and wirespeed and it went ok
i welded inside and out on this part as it is high stress area
i have also managed to overcome the lack of lights i have
i then got on with cleaning it up and a bit of paint
and also got round to painting the inside of the front repair
and this is how it was left tonight
bolted and clamped up for its final fitting
so hopefully get this done later in the week but for now thats all
as always comments more than welcome Darren
thats looks really good.  can you tell me what thickness plate you use for crossmember repairs?
#708 Minidarren83
Minidarren83
  • 1,207 posts
Posted 16 October 2014 - 04:43 PM
That should all be 1.2mm steel mate heel board, toe board and crossmember all 1.2
#709 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 October 2014 - 02:03 AM
The car is all flatted down to 2000g and I've spent a few hours this evening making it look like a spaceship
C60220DD-9275-4E85-93F6-5C8D0C612B88_zps
4F1CCF8A-9465-4448-B922-FFDE59AA6813_zps
#710 bluemini17
bluemini17
  • 158 posts
Posted 22 October 2014 - 07:56 PM
great progress, may I ask what product you used for the inside? I had thought of using the lead flashing approach
#711 Minidarren83
Minidarren83
  • 1,207 posts
Posted 25 October 2014 - 01:18 PM
It was from eBay and came from china I think search 64 sheet sound deadening
#712 Minidarren83
Minidarren83
  • 1,207 posts
Posted 25 October 2014 - 01:25 PM
So I may I screwed my paint it seems when I was wet flatting that something was on the osier that I didn't know was there. The paint looks good in the pictures but once you get close there are scratches all over it that can't be polished out
1DADC9FC-3C6B-416F-809A-62E3A8962466_zps
66FC4707-B87B-4822-B2AA-91DF557A7B94_zps
And a reflection shot which is perfect no swirls or holograms
43C261F2-8418-4736-A0DE-CB0320AF6D4D_zps
But this is the damage done and it's all over the car not too bothered about the back and sides I can deal with it on the gray but the black roof needs to be to a good standard
48DA09C6-57E1-4DB9-8759-C58DD225D0BA_zps
Going to try some abralon discs see if I can get them out without going too deep
#713 Minidarren83
Minidarren83
  • 1,207 posts
Posted 14 November 2014 - 10:30 PM
Update time
Having the engine crane came in handy again this week
B6A523F8-CCCC-4499-A387-FF5160D01A8C_zps
I needed to do some paint repairs to the underside from when I moved and scrapped it all on the trailer so on with stonechip and then black
3022DC16-E723-448B-9EB1-5280A276AFF6_zps
And also welded on the rose joint stabiliser brackets
3F161385-3145-420C-ACC9-B38050A44BF0_zps
And made the gearbox bracket
FECC2BA6-A079-4FC7-9319-844AF464AEBE_zps
This is where it lives
87021888-86B3-4C0C-9C4F-87135B5270E6_zps
And also modified my previous lower steady mount by drilling a 14mn hole
F47E0E4A-DF4F-4394-BD0A-8C2F2290EEE6_zps
Which allows me to fit this
D8F02FAE-CA55-4F88-92C7-1187A42B5120_zps
I've got some cds tube to make spacers but I need the engine back in to work that out. Also started running my fuel lines but I've managed to order the wrong fittings and not enough hose
58BCA6C4-8613-4AB3-93F7-524F333CAC00_zps
6F984C9F-E111-4404-B3DB-A7EE766E817D_zps
And lastly this week started fitting up the new front before it gets hard with the engine in just trying to secure it to the flip hinges
247337E8-80BD-473A-88D5-22C2B80A778B_zps
I think I may have trimmed a little too much from the scuttle gap
7352B6E6-E672-4CC1-9DF6-FE2F10E05118_zps
Wiring is almost done so should be ready to plug in the engine loom soon
That's all for now cheers
#714 hoody99
hoody99
  • 699 posts
Posted 17 November 2014 - 10:38 PM
What hinges you using bud. Can always fix it like I did mine. Stiffens the front up a bit to
#715 Minidarren83
Minidarren83
  • 1,207 posts
Posted 18 November 2014 - 04:32 AM
I'm just doing the same as I did the round nose one rover 75 boot hinges with an internal locking latch from my donor mg zr
#716 Minidarren83
Minidarren83
  • 1,207 posts
Posted 20 November 2014 - 09:53 PM
Well another update I've spent the last two days trying to get the floppy fibreglass front fitting well on my hinges.
To start with the clubby front has more room up top but seems to curve in much more at the bottom so I had to take two cuts out for my tiebar mounts
81B3F819-4ED1-4014-A3A5-43851F57AEDD_zps
I might cover these with glass or just leave them as when the ride hight is set unless your under the car you will not notice. The. Made some mounts out of 3mm flat bar nuts and spacer tubes but forgot the picture and then glassed them onto the front
E4F5E2C3-DFF7-4F20-AC4E-36149D10B198_zps
And also glassed a piece of hardboard along the scuttle edge to stop the flex
848E3352-2781-4E9B-A273-54E5D7F15D17_zps
And this is what the flexing was doing taking **** chunks out of my freshly painted scuttle best I oaint that again
FE021094-10FA-417F-954B-50BFA4CE64A3_zps
And this is the final result (click for video)
http://s1166.photobu...0eo2lr.mp4.html
Still some adjusting to do and mod the headlight area to accept a standard grill and light setup but almost time to put the engine back in
Edited by Minidarren83, 20 November 2014 - 10:00 PM.
#717 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 20 November 2014 - 10:06 PM
Great work darren, shame thats it's chipped the paint. Are you going to fit a proper clubby grille or leave the fiberglass bit? Were you working in your dressing gown today :lol:
Edited by alex-95, 20 November 2014 - 10:06 PM.
#718 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 November 2014 - 11:48 PM
Love the action of that front Darren.
Really is excellent, you must be pleased.
I was also going to ask about the grille, Looks a bit like a Reliant Regal 3/25 s it is  :lol:
No offence of course if that is how it is staying  ;D
Keep it up
Ben
#719 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 November 2014 - 04:39 AM
Cheers lads and no it's not staying a standard grill will fit or I'll bin the front and get a better mold lol
And alex i was just taking pics in the dressing gown it would go up in seconds if I worked in it lol
#720 frodmyster
frodmyster
  • 214 posts
Posted 21 November 2014 - 01:00 PM
Nice project :)
    Bing (1)
