The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#646 hoody99
hoody99
  • 699 posts
Posted 25 June 2014 - 09:00 PM
Yes come on the slab fronts ha ha good lad same front as mine I think which means you can't fit the original grill, bummer really. But good lax on the change you kept that on the down low
Ha cheers mate I think I'm going to have a go at a standard grill I just love the flat front look
Look foreword to see how you do this as it looks a pig to me as the original front had the headlight mounting panel about 1 1/2" back where as these fronts have about 1/4" lol so will need compleat lay cut out and recessed back further if you get me lol
#647 Club man
Club man
  • Just Joined
  • 130 posts
Posted 26 June 2014 - 09:40 PM
Coming along well mate, would be good if you can get a proper grill in there.
Give me a shout if you need any measurements mines stripped out at the moment, and i have got a grill you can loan while i don't need it if you want a try anything out before you have to get one
#648 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 July 2014 - 05:11 PM
Cheers mate I'd love some measurements of how deep the headlight mounting point is and a few detailed close ups of that whole area. That would be great
Darren
#649 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 July 2014 - 05:20 PM
Bored of sanding already so.
Gear linkage mk3 ish
Made up this little bracket
D17BF4F8-AC32-418A-A233-6B0A740D05B5_zps
D6DDB4F2-E2A7-4764-958E-436C5E2BE815_zps
That fits on the gear change like this
D2494F35-064B-48EA-9087-28949B7092DB_zps
It will bolt directly to the tunnel so it solid mounted and on the front to control the front lift ill use this with a couple of spacers in a hole drilled into the change mech
5477545D-3181-43E7-BA8C-67ABC7FF596C_zps
Il get it bolted in in the next few days so more to come
#650 Minidarren83
Minidarren83
  • 1,207 posts
Posted 02 July 2014 - 08:48 PM
Bolted all the linkage in today looks much better than my first attempts
5C339392-7D4E-486F-93BD-0330502FB5DE_zps
080A3DE8-C02D-4A87-B598-2DF4ABC8B277_zps
The only problem now with bringing inside the car and turning left slightly is the gear stick in center sits like this
99D7FAFC-A518-4987-A42C-4E8AA69A6608_zps
So on that note does anyone know if this can be moved?
6E1B6537-213D-466C-964A-19E218A809F4_zps
Failing that if I was to drill and tap in a grub screw in this possition would it still operate the same?
F7AAD0A4-A76B-4B08-B7C3-D86DE01C1E20_zps
#651 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 July 2014 - 02:51 PM
I went a different route in the end just ground a new slot into the gearstick end
7AA3F0A6-4018-4CE2-870C-683A0FE7017A_zps
And it sits just where I want it now
1C9F5F3B-F407-4E85-94CE-1018DE58DAC5_zps
46535BA1-536E-45F5-8E9B-8BAF073485C0_zps
#652 Club man
Club man
  • Just Joined
  • 130 posts
Posted 03 July 2014 - 09:45 PM
They are a bit dark, but let me know any areas you want more of and i will use a better camera
Let me know what bits you want measurements of, the head light brackets are 60mm deep on the outsides and 70mm deep towards the middle
#653 Minidarren83
Minidarren83
  • 1,207 posts
Posted 06 July 2014 - 05:57 PM
Got the steering column and drivers seat done today
I started by pressing/violently hammering the end of a mini steering column into the fixed uj on the rover one it doesn't fit normally so a tickle with the grinder is needed
2B35D4BB-F382-4EB6-B0D5-F06155AF34CA_zps
CF993FC7-BF05-4C2C-B077-E3CEDD86D185_zps
I then welded the joint so it's not going anywhere now
Then using parts of the rover column and bits of the mini I got it all fitted
7F2F4B0F-880B-4A66-AFF2-7ECB8F33E355_zps
C43E8A00-E19C-4060-8D03-E32A5DF8C275_zps
Also fitted the drivers seat using a modified subframe
754D80B5-E47C-4336-8501-1A905CF370F1_zps
Really happy with my driving position
78C94220-7841-4B51-A84E-71497CD6E7E1_zps
#654 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 July 2014 - 06:23 PM
looks good Darren.
Whats the reason for using the rover column?
Ben
#655 Minidarren83
Minidarren83
  • 1,207 posts
Posted 06 July 2014 - 06:46 PM
looks good Darren.
Ben
I'm using the full rover loom and stalks plus I get to keep the immobiliser in the ignition ring and then the fact that the rover column is far better using bearings and makes the steering much smoother
#656 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 July 2014 - 07:00 PM
nice one. I never knew that about the bearings.
#657 Minidarren83
Minidarren83
  • 1,207 posts
Posted 10 July 2014 - 09:24 AM
Got the clutch sorted out yesterday.
Started by modifying the pedal
7BBED99D-96F2-42B2-BBE0-0154D0CDB688_zps
Then made this plate for the bulkhead using the original cup off the mg pedal box
16D3F636-57B0-4285-B283-B3042D6F5B97_zps
Hooked it up on the inside
ED7E92D2-A85A-4D95-9A44-B16D620AA847_zps
The wheeled the motor over to try it out works perfect
64CA6672-FA3C-41B1-81D8-FBB5037D98DA_zps
Another job ticked off the list
Edited by Minidarren83, 10 July 2014 - 09:25 AM.
#658 Minidarren83
Minidarren83
  • 1,207 posts
Posted 19 August 2014 - 12:15 AM
We'll it's been a few weeks with no real update but the mini is now fully prepped for paint weeks of filling sand and repeating but it's done just need to clean out the garage and paint it
5E2B4BC2-9154-4F47-A013-A49FAC0ECFA1_zps
58D0BCE0-9C33-451B-939E-DBE51CBF7349_zps
B3E758F0-F14B-42C8-80F3-373D084C225E_zps
02140CDB-B3E0-48FA-A1F0-6CFA90B93937_zps
F05EC3EC-3A30-431B-867B-8032C32A852A_zps
#659 Carlos W
Carlos W
  • 10,114 posts
Posted 19 August 2014 - 03:29 AM
Little and often and you soon make progress mate
#660 hoody99
hoody99
  • 699 posts
Posted 22 August 2014 - 11:11 AM
Oooo time for the good bit ha ha any colour in mine chap. Great work so far buddy, I know it's hard when life gets in the way but as above, little bits often and it will be done before you know it.
