The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#466 Minidarren83
Minidarren83
  • 1,207 posts
Posted 30 September 2013 - 09:41 PM
hi mate your project thread is great ive been studying it for the last hour, thanks for the links to panels you sent me earlier.... can you link me to the rh inner wing please  and let me know how the scuttle ends fitted and where you got them thanks
Hi there mate glad you liked the thread any questions don't hesitate to ask the inner wing came from a member off here but it is this part from minispares
http://www.minispare...Back to search.
I would strongly suggest a full scuttle and genuine one at that but the ends can be fitted with a lot of work and filler ill link you to both ends and the full one
A cheaper less well fitting alternative
And then the end pieces should you go down the route just search the site for the other side
http://www.minispare...MS.aspx|Back to
And whichever route you take to repair the scuttle you will need one of the closure panels for either side
http://www.minispare...6L.aspx|Back to
Hope this is what you are looking for
Darren
thanks mate i have just bought the panels you linked me for the A post repair i didnt buy the full doorstep A post i got the part doorstep one as its alot cheaper thanks again for the links
No worries man any time although you may regret not getting the full step I do until this day!!
#467 carlburt78
carlburt78
  • 239 posts
Posted 30 September 2013 - 10:00 PM
Darren
to be honest il probably will regret it but as this is my first ever project (that happens to be quite rusty) just to have it solid will be a great achievment for me .and at the moment i havnt got a clue as to what panels to repair or replace first , but after help from you guys im thinking it will be best to start at the door post area and work back..............
#468 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 October 2013 - 02:47 AM
 [/quote]
to be honest il probably will regret it but as this is my first ever project (that happens to be quite rusty) just to have it solid will be a great achievment for me .and at the moment i havnt got a clue as to what panels to repair or replace first , but after help from you guys im thinking it will be best to start at the door post area and work back..............[/quote]
Yeah I see your point this was my first mini too and cost was a big factor for me. As for where to start I would put a question out there in the bodywork section as there is no right way to do it but a logical one. I started on the floors so that I had some solid inner sills to weld the steps too on one side then on the other did the a post before the step. Whatever you choose to do, finish one bit before moving off or you will just a have a list of unfinished bits
Darren
#469 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2013 - 07:09 PM
So last couple of days update
Not done a massive amount but it's something made a start on the rear arch renewal and cut the old one out
Then seeing as this is the last time I will have major access to the boot I cut the skin off an old boot lid and taped n tied it in place
Then started on the internal hinges that will flip up to match the front pulled the old bonnet hinge mounts off as they seem a foot place to start with and clamped some 3mm between them to get the spacing needed
Then using my marks made with the boot kid on I welded then to the parcel shelf
I must also admit at this point I have run out of gas so it's gasless until I can get some more 😔
More soon cheers
#470 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 03 October 2013 - 07:14 PM
Good work darren, like the idea of the boot, something different. Are you planning for it to swing right the way around so it's vertical again?
#471 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2013 - 07:25 PM
Yeah it will go right up or getting anything out will be a pain also hoping to have it on a gas ram also like the front just need to work out a mounting system so it can't be seen
#472 alex-95
alex-95
  • 6,025 posts
Posted 03 October 2013 - 07:31 PM
Sounds good, Just need to be careful how you mount it. Have a look at bluebloods minus if you haven't already he had a problem with his internal boot hinges.
http://www.theminifo...a-minus/page-24
Edited by alex-95, 03 October 2013 - 07:32 PM.
#473 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 October 2013 - 07:51 PM
Yeah saw that the other day it's all about the pivot point being as close to the point you want to pivot round ie the rear panel lip
#474 hoody99
hoody99
  • 699 posts
Posted 03 October 2013 - 09:33 PM
I thought about doing this also, as i wanted an internal hinged boot but the tank got in the way. so thought about this way and talked myself out of it lol. Look foreword to how it turns out. You going for a G/F skin ?
#475 Minidarren83
Minidarren83
  • 1,207 posts
Posted 04 October 2013 - 03:04 PM
I'm hoping it turns out the way I want but I'm staying all steel and keeping the number plate recess too so going semi smooth with internal lock
#476 Minidarren83
Minidarren83
  • 1,207 posts
Posted 16 October 2013 - 11:28 PM
Not a lot been happening the last couple of weeks but still working on the internal flip up hinge and have made many attempts at it
Mk1 2 and three none worked
Then came up with this it's only rough in thin steel so far but is a double hinge it pivots once under the parcel shelf and again on the boot itself. The first part of the hinging will be by gas ram then flip it up by hand from there
The bit at the top is the new mount as the old ones were too far away from the pivot point and they will sit right under the parcel shelf on the rear panel I should get them cut into thicker steel tomorrow and welded in
Cheers Darren
#477 hoody99
hoody99
  • 699 posts
Posted 17 October 2013 - 12:37 AM
Just a question if it flips up the way are you moving the lock to the bottom of the boot lid or using lockable catches ??
#478 Minidarren83
Minidarren83
  • 1,207 posts
Posted 17 October 2013 - 02:24 AM
I will be using an internal lock at the bottom most probably from my mg donor car just not sure weather to make it electric pop or cable with the battery being in the back I'm leaning towards cable
#479 Minidarren83
Minidarren83
  • 1,207 posts
Posted 17 October 2013 - 02:16 PM
Got all the mounts and one hinge cut out in 3mm it took forever with the carbide burr so only one hinge today lol
And for anyone that wants to know this is how the hinges will mount to the rear panel
Should have the other hinge cut out tomorrow then start mounting it up
Cheers Darren
#480 Minidarren83
Minidarren83
  • 1,207 posts
Posted 25 October 2013 - 06:09 PM
Well the first few tries of the hinges didn't work at all so back to the drawing board made the first "new" one Fromm 6mm bar but it was too thin so made it again from 8mm which is much stronger and they curl up into the a cut out in the parcel shelf. Wish I never started now but ill get there in the end then I can move on
Cheers Darren
