The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#391 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 27 July 2013 - 05:46 PM
That looks fantastic, dude! Coming together so fast now :D
So when do you want your frame done? Lol
Ahh man, you always know how to cheer me up.
Added another "hiccup" on the coupe list today.
Get your frame finished and finalised, your baby has to come first ;-)
But I think flip fronting Ogy might be a good way to go, ease of access / adjustments.
Need to get a look on the auto tranny to see how the size and mounts differ.
#392 Minidarren83
Minidarren83
  • 1,207 posts
Posted 27 July 2013 - 06:35 PM
And what is the latest hiccup?
When mine is done ill gladly knock you up a frame I think due to the size of of the auto sticking out the back you may need to go clubby at the least and maybe even extended so the engine can sit further forward
#393 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 27 July 2013 - 06:42 PM
Hmm interesting, there's 2 or 3 guys have squeezed an auto in the stock length so it must be possible. Just very tight :P
Can always make a small box for the bulkhead.
Hiccup is the oil pressure light... doesn't. Checked the bulb and back half of the circuit today, tomorrow I'll ground it to confirm if it's the sensor.
Either way I've gotta call the dealer.
Ho hum, anyway enough of that. Weld your frame up and show us the engine fitted! :D
#394 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 28 July 2013 - 03:26 AM
The best part of a night shift, catching up on this project. Brilliant work dude!
#395 Minidarren83
Minidarren83
  • 1,207 posts
Posted 28 July 2013 - 05:12 PM
Cheers mate thanks for taking the time
#396 Minidarren83
Minidarren83
  • 1,207 posts
Posted 31 July 2013 - 07:12 PM
Had a good day today prepared the daily for the mot needed two tyres a cv boot and a few odds and sods then carried on with the frame. Dropped the engine in and instantly could see the engine could be lifted an inch or so but that's for another day so concentrated on the rear mounts.
Made up a simple but affective jig to hold the rear floor mount position then cut the rest if the frame out
Then tacked together the bits I'd measured and cut earlier to formtbesame shape as the old frame parts
And this is how the frame is looking now shame I only had a hour I this today
Got tomorrow afternoon to do more so that's all for now
#397 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 August 2013 - 05:56 PM
Bit more done today
Started by cutting the excess of of my solid floor mounts to leave just a flat plate
Then cut and tacked in the rear arms
Got a pretty good fit on these the angles were all over the place
Then replicated the other side and bolted on to the car. I know it looks a little off but I madrone side of my cross brace sit further back for the extra few mm clearance in the gearbox
And this is how it sits now just need to raise up tfe top arm 30mm and its done. No more now until Monday so see you then. Darren
Edited by Minidarren83, 01 August 2013 - 05:57 PM.
#398 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 01 August 2013 - 06:34 PM
That is SMEXEH!
Looking ace, dude. Engine in on Monday? :P
#399 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 August 2013 - 07:58 PM
That is SMEXEH!
Cheers mate. Yeah should have it all in on Monday unless I decide to change something again lol just two new arms to cut and its done
#400 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 01 August 2013 - 08:08 PM
Awesome!
I'd be there for the big fitting but the head is being collected, although If it goes early... :D
#401 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 August 2013 - 08:51 PM
Well I might be working yet I put in for extra shifts so ill let you know even if off might not be able to get out there as wife's off work too so plenty if jobs around the house lol
#402 Minidarren83
Minidarren83
  • 1,207 posts
Posted 02 August 2013 - 01:51 PM
Well I did say no more play until Monday as its the wife's birthday but she went shopping. I had a little parcel this morning
Then raised the top arms up 30mm looks the same as the last post unless you know what your looking at lol
Then dropped the motor in and out the front on
And then some of my fitment issues I need to take a notch out for the oil filter neck bit
And the gearbox bell housing but the removable front bar will sort this out
And under the bonnet
And the most worrying part is the water outlet it's pretty close to the grill I just hope I can get a tight enough bend on the hose
That really is all for now lol
#403 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 02 August 2013 - 02:03 PM
Ahh, sweet! Presents all round then :P
I bet the oil sender pipe is really thin walled, should be able to get a mm off of it though and maybe a nibble out the frame upright?
One water outlet I reckon you could shave the pipe back some, depending on how long it is.
Otherwise just add a spacer onto the back of the grille to bring it out 5mm or so, will never notice once on the car.
:D
#404 Minidarren83
Minidarren83
  • 1,207 posts
Posted 02 August 2013 - 02:08 PM
:D
Im going to take all the room needed out of the frame the oil pipe will be far too thin. Never thought about trimming the outlet down also could do with moving the temp sensor too also the frame needs to be wider on the gearbox side only by 20mm or so just the same as the other side
#405 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 02 August 2013 - 02:13 PM
I think, and I could be wrong but moving the temp sender shouldn't be tricky job. Plug / weld up the old one and tap a new hole.
Well seems you've got some tweaking to do before building the next one :D
:whistling:
