The Wifes Worst Nightmare 83 Full Resto
920 replies to this topic
#211 Minidarren83
Minidarren83
  • 1,207 posts
Posted 02 March 2013 - 07:23 PM
SOOOO!! the big update never came just been too busy at work all you lot wanting too much petrol and diesel means 12+ hours a day and no energy to work
after that but i have a few bit for you all and a few quwstions. so i will start of with my latest buyings from the great bay
got myself some of these little badboys 10x6 with as new tyres £130 not bad i think just need to be black
then these are the hinges from a rover 75 i will use to lift the front end up work just the same as minitec ones but the only cost me 15 delivered and are probably better made too plus they have a built in strut
they will fit here on the inner wing when chopped a little on a custom bracket
and will work like this to move the front forward and up allowing the bonnet and wing corners to clear the scuttle
now for my questions i have fitted the door back on and offered up the a panel but at the ends of the scuttle there is massive gaps is this normal?
and then after the trail fitting the a panel the seam that the new scuttle end has is no where near where the a panel needs to meet it can i just slot this add a little strip and weld up?
hopefuly some of you will have the answers as i need to get this moving on and will be in there tomorrow and have tuesday off too so should get some more done
cheers for looking and sorry its not much darren
#212 minimikej
minimikej
  • 349 posts
Posted 03 March 2013 - 12:24 PM
Guessing it's not the Heritage scuttle? First things I'd check how the fit you currently have lines up with the outer wings, it may be the scuttle itself which is off. Make sure you get the bonnet in place too when doing any front end work. I would expect to have to cut slots in the scuttle, reshape and weld up. The fit with the front wings is crucial to get right.
Good luck!
Mike
#213 grahama
grahama
  • 2,442 posts
Posted 03 March 2013 - 08:06 PM
Hi Darren,
Like the hinge idea, very clever thinking, and the Wellers are ace, I love mine and I think nicer than Minilites. On the scuttle front, mine were exactly the same when the ends were replaced and I just put a filler piece in the gap you have to close it. The wing covers it all up anyway but I think it should be closed so I closed it !!
ended up like this
wing cover like this
Couldn't see any other way of doing it but it turned out fine. Also if you have a sneaky look in Mini Luke's Gunmetalmini thread he has just put in a new scuttle and it is closed up.
regards,
Graham
Edited by grahama, 03 March 2013 - 08:21 PM.
#214 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 March 2013 - 09:10 PM
Good luck!
Mike
Thanks for the tips mike it seems that the cheap scuttle ends are the problem and I will just have to add a piece in
Darren
#215 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 March 2013 - 09:18 PM
Hi Darren,
ended up like this
regards,
Graham
Ha funny you should put these pics up only today I read back over your thread as I know you did the ends of your scuttle. This is why we put so many pictures up so we can learn from each other
#216 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,073 posts
  • Name: Neil
Posted 03 March 2013 - 09:19 PM
Even Heritage panels leave gaps but certainly nothing that big. Nothing that a small section of metal wont cure though.
#217 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 03 March 2013 - 09:23 PM
Think it's a non genuine scuttle end problem, that's a Heritage panel in my pic
#218 Minidarren83
Minidarren83
  • 1,207 posts
Posted 03 March 2013 - 09:33 PM
I did see on your thread you had a gen one but I'm just too tight to pay out for it lol but next time this is one place ill pay for genuine the repro ones are terrible
Cheers Darren
#219 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 March 2013 - 08:47 PM
big day today i was slowly loosing interest and momentum on the build so needed to spur myself on so this happend!!!!!
and next comes the usual overload of pictures showing my panel gaps ive managed to smash, bash and cut into the repro panels
bonnet gaps are ok not the best but it will more than do for a daily driver
and as i am too tight to buy front mounts that i dont need for the flip front i used some 12mm ply in their place
the a panels are way off one side gaps too big other side too small but they will come out ok i think just need to use the hammer some more lol
all the panels are just tacked together at the moment and will be removed and fully welded to make the one piece i need to cut the upward return lip from the wings so i can weld the bonnet on and squeeze some sealer in the gap but i still need to close up the scuttle ends which i will get done tomorrow
and one last pic because i love em. my garage is a little full at the moment
as always comments and suggestions welcome cheers darren
#220 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 05 March 2013 - 09:02 PM
That's not a bad bonnet gap at all dude, especially given the interesting panel combo!
Glad you're feeling the buzz again. Mine withered about 20mins after getting the bracket in, due to... problems :mmkay:
#221 grahama
grahama
  • 2,442 posts
Posted 05 March 2013 - 09:30 PM
Darren,
that's exactly how I was with my wings and a panels, ended up slotting and piecing the pass side and shuffling the driverside about but it fit in the end. A nice job so far, just some more fettling and you'll be there.
Graham
#222 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 March 2013 - 10:15 PM
Cheers graham it should come together fine a few cuts here self tapper there lol
#223 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 05 March 2013 - 10:19 PM
Cheers Darren
It's the only gen panel I'm using and there are certainly lots of panels!
#224 Minidarren83
Minidarren83
  • 1,207 posts
Posted 05 March 2013 - 10:22 PM
Cheers Darren
Ha ha I only have two inner wing and floor half tge rest is just cut and shut non gen takes a while but they all fit the same
#225 Minidarren83
Minidarren83
  • 1,207 posts
Posted 11 March 2013 - 06:26 PM
UPDATE TIME!!!
managed to get the apanel door gaps spot on so needed to close up the scuttle ends and as it will be a flip front it was important that they looked presentable so as always lots of pics to show the process
started by making a card template and cutting in steel tried my best to follow the line of the scuttle and its curve
then tacked and fully welded
then cleaned off and primed very happy with this side
now this side started off horrific and i wasnt going to show it but where would that get me im not perfect. i decided to weld it to the flitch but the other side will just be sealed i think
cleaned up ok and will be fine with a skim of filler
not much as it seems to be the way lately but plodding along and more to come this week
comments welcome as always Darren
