Brake Pedal Randomly Going Soft!
Posted 16 July 2012 - 04:29 PM
Very rarley but randomly i press the pedal on my brakes and it goes really soft and the brakes barely work. The pedal doesnt spring back up
But drive on a little bit and next time i try too use them they are back to normal.
This is dangerous as you can imagine.
The Brake fluid resovoir is full and the calipers are on the right way, (Bleed nipples to top)
Any ideas?
Posted 16 July 2012 - 04:35 PM
Posted 16 July 2012 - 04:37 PM
If so check the wheel bearings
Posted 16 July 2012 - 04:39 PM
Drove down the road abit and it was hard and working fine again
Posted 16 July 2012 - 04:42 PM
Posted 16 July 2012 - 04:45 PM
Posted 16 July 2012 - 04:46 PM
Posted 16 July 2012 - 05:17 PM
Posted 16 July 2012 - 10:11 PM
Posted 18 July 2012 - 03:26 PM
Posted 18 July 2012 - 05:25 PM
I had a similar problem when the tapered washer started to fail on the hub.
Posted 18 July 2012 - 06:15 PM
Posted 19 July 2012 - 03:56 PM
You also most definitely have a defective pedal to master cylinder linkage, or faulty master cylinder, or both, if the pedal is not returning, which is the definitive clue to where at least one problem must lie. Is the large and very important pedal return spring intact? Is, and it is very important, the master cylinder pushrod returning fully every single time? Is it slack when the pedal returns? (If it remains tight, the master cylinder may need shimming.) Is something down there jamming in some way? Has the clevis pin fallen out?
Sorry, but it is going to mean contortions in the footwell, most inaccessible part of the car, to sort this one out. You may want to raise the car very high, on the edge of a loading bay for example, and stand outside with the door open, or take the driver's seat out, put down something soft, and lie on your back, to get to the pedal mechanism and clevis pin.
Edited by tiger99, 19 July 2012 - 04:06 PM.
