Canadian Mini 30 First Ever Rebuild!
198 replies to this topic
#106 30 mm
30 mm
  • 181 posts
Posted 17 March 2013 - 09:52 PM
And the other side.
Tomorrow I plan to fit the inner sills however I am not optimistic about welding them in. Plus work has me away later this week for two weeks so its a shame but it will have to wait.
30
#107 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 19 March 2013 - 10:07 PM
I'm no expert in the slightest but its not looking too bad for someone who has never done this before
Good work
#108 30 mm
30 mm
  • 181 posts
Posted 20 March 2013 - 02:44 AM
Thanks Kam!
Im on a plane soon and away for the next ten days. In a rush I fitted the inner sill to the left side and its good. When Im back I have a week at home until a week on vacation so I plan of having all sills, floor pans and flitch panels done. By that time it will be warm enough here I can attack my integra and pull it apart and clean up the rear subframe.
30
#109 30 mm
30 mm
  • 181 posts
Posted 21 March 2013 - 11:40 PM
Fellas,
Im replacing both rear subframe mounting plates! Any idea what the bes way to get these on straight so I dont have a surprise once I try to mount the rear subframe.
Obviously Ive made my measurement from one mount to the other but how can I get it dead on.
30
#110 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 21 March 2013 - 11:47 PM
Tack them in with the subby fitted, no nasty supprises then
#111 30 mm
30 mm
  • 181 posts
Posted 18 April 2013 - 09:27 PM
MINI LUKE thanks for that idea.
Here I need some help again. I have this one mount on the bulk head that is rotted behind. When Fitting the mini tec subframe do I need this mount or can I just get rid of it and slap new metal there.
THanks
30
#112 KieranB
KieranB
  • 360 posts
  • Local Club: S.U.N.M.C
Posted 18 April 2013 - 09:32 PM
As far as i am aware with the minitec subframe, the lower mounts are underneath the car and require 3 holes each. That mounting place isn't used but even if it was and yours is rotten.....well seems like the best option would be to ensure its strong enough. New metal would be my plan of attack
Kieran
#113 30 mm
30 mm
  • 181 posts
Posted 18 April 2013 - 09:37 PM
KB Thanks,
I just had a look at the MINITEC pdf file for the MTB frame and your right. Of course I will replace the metal for sure but I was wondering if I had to order more bolts and stuff to replace the rot of the mount which doesnt look like its the case!
30
#114 30 mm
30 mm
  • 181 posts
Posted 24 April 2013 - 10:42 PM
Got the rear subframe apart tonight. Ill be getting it ready for a sand blast and paint next week.
The floor is complete along with the inner sills both sides. The floor panels are done and now Ive decided to do some work on the bulk head. So still more welding to be done.
So much rust
30
#115 30 mm
30 mm
  • 181 posts
Posted 27 April 2013 - 03:35 PM
RIP angle grinder.  20$ made it far enough!
Floors are in and now a little work remains on the bulk head before we put in the flitch panels at the wheels wells.
30
#116 30 mm
30 mm
  • 181 posts
Posted 30 April 2013 - 12:21 AM
Does anyone have a rear subframe parts explosion diagram
thnx
30
#117 30 mm
30 mm
  • 181 posts
Posted 05 May 2013 - 04:19 PM
Front floor boards and bulk head with wheel wells done. Really a two small parts remaining to be welded but for now Im getting the B16 out of the integra while its warm out here.
30
#118 Kam
Kam
  • 4,140 posts
Posted 07 May 2013 - 11:21 PM
Still need it? Chapter 21?
http://www.minispare...985-2000.aspx?2
#119 30 mm
30 mm
  • 181 posts
Posted 24 May 2013 - 09:18 PM
Kam thanks for that.
ALL!  I am taking out my B16 out of the integra tomorrow and then I sell the car to scrap.  Ill make sure to get the wiring loom and save the heater, AC and a couple other small things.  Any ideas as to what else I can use from the car in the mini.  Also, from the front end is there anything else I can use there.  I will be using the MTB2 frame.
30
#120 KieranB
KieranB
  • 360 posts
Posted 24 May 2013 - 09:37 PM
It entirely depends on how you plan on doing the rest of the build. Fueling? Coolant? I'm not sure about integra's but keep the gearlinkage, engine mounts, any pipes/hoses and radiator plus maybe gauges depending on what you want to use and maybe fuel pump. If you've got the room and are scraping the car you might aswell keep as much as possible but the above will help with the conversion
Hope this helps
Kieran
