Canadian Mini 30 First Ever Rebuild!
198 replies to this topic
#76 30 mm
30 mm
  • 181 posts
Posted 14 September 2012 - 05:30 PM
I hope this will support the car!
At the front I have wood blocks on the underside of the firewall and two 2x4s on top as you can see in the pic. And at the rear I hope the 2 x4 s are long enough!
Let me know what you think about this set up anyone.
30
#77 30 mm
30 mm
  • 181 posts
Posted 14 September 2012 - 08:00 PM
Well, The wood blocks work well.
Another milestone. Now to buy some panels!
30mm
#78 30 mm
30 mm
  • 181 posts
Posted 17 September 2012 - 11:54 PM
Well,
Got a good look at the underside today. I was hoping to identify what parts were rusted so I could buy replacement panels but honestly I dont even know what some of these panels are called!
30 mm
#79 dasupersprint
dasupersprint
  • 848 posts
Posted 18 September 2012 - 02:34 PM
Hi,
By studying exploded views of panels in catalogues you will sort out wich bit goes where!
#80 30 mm
30 mm
  • 181 posts
Posted 18 September 2012 - 09:27 PM
Thanks dausupersprint.
Thats what ive been doing but I guess I dont have a good view. Im trying to understand the outer and inner sills as well as what I can weld on my own without buying panels. Ill keep you posted.
30
#81 30 mm
30 mm
  • 181 posts
Posted 20 September 2012 - 08:42 PM
Question.
I will replace the sills. However parts of the first grove of the floor panel is also rusted but there is no need to replace the whole floor. Is there an issue that I can not foresea if I replace the metal and its not in the shape of a grove?
thanks
30mm
#82 30 mm
30 mm
  • 181 posts
Posted 26 September 2012 - 07:20 PM
Well I continue to bash on.
Ive been able to exchange my 998cc to a supplier of panels here and so this weekend we will make a swap and Ill have all the panels ready to add to the car minus the front end! Pretty excited
30
#83 30 mm
30 mm
  • 181 posts
Posted 27 September 2012 - 06:08 PM
Good bye 998cc!
#84 30 mm
30 mm
  • 181 posts
Posted 28 September 2012 - 03:00 PM
Well the engine is gone!
And the new panels are in!! A lot of work ahead of me now. A new chapter begins.
#85 30 mm
30 mm
  • 181 posts
Posted 03 November 2012 - 05:47 PM
Mods,
Thanks for sending this to the Honda vtec threads. Thats right. Ive decided to put a VTEC B series in my 30.
For the time being Ive welded some support between the door frames for when I cut out the door step and the back end of the trunk (boot) has been cut out as well for a new panel to be welded in.
Best.
30mm
#86 30 mm
30 mm
  • 181 posts
Posted 04 November 2012 - 07:39 PM
MILESTONE!!!
First new piece of metal welded today. In the boot. Lesson learned... replica panels... not so much.
Starting to think now which sub frame to put into my mini. MINI TEC?
30
#87 30 mm
30 mm
  • 181 posts
Posted 05 November 2012 - 12:58 AM
SUBFRAME question.
Should I go ALLSPEED or MINI TEC subframe?
Please chime in here.
30 mm
#88 miniblade81
miniblade81
  • 218 posts
Posted 05 November 2012 - 07:32 AM
hi there have you got donor car or just engine i had a go at fitting one of these engines and found it too costly but prices are lot better now as frames go allspeed looked a good frame but isnt mini tec made in usa and be easier for you to get and if i remember right bulkhead mods are needed for both or inlet mod and maybe gbox but suppose depends on kit type ie bare frame or not
#89 KieranB
KieranB
  • 360 posts
  • Local Club: S.U.N.M.C
Posted 05 November 2012 - 09:48 AM
subframe choice is entirely up to you, i have the allspeed frame. its a nice piece of kit and easy to install. i wouldve probibly gone for minitec if it wasnt for import tax etc, johny on here has it and matched with the coilovers it does look really smart.
but like i say its up to yourself. being where you are maybe the minitec is the more practical option
kieran
Edited by KieranB, 05 November 2012 - 09:48 AM.
#90 30 mm
30 mm
  • 181 posts
Posted 05 November 2012 - 01:21 PM
Sounds about right for the mini tec.
Converted to CDN $ the allspeed is 1000$ and the mini tec is 2300 subframe only and 3200 with parts like the rad that fit under a round nose. I have to find out what my total cost will be for the allspeed to come into canada.
Also, coil overs will go into the front. Should they also go to the back?
30
    Bing (1)
