No Spark At Points
Posted 13 July 2012 - 05:44 PM
New mini spares wirining loom, new Aldon dizzy, new coil and leads. All fuses ok I have voltage at the coil. When I turn the engine over the + terminal goes 12v then 0 as if the poit are switching but I cannot see a spark between the points and again with cap back on and plug shorted no ht spark. I suppose the dizzy could be faulty but it is brand new. Any advise appreciated thanks
Posted 13 July 2012 - 05:51 PM
Posted 13 July 2012 - 05:52 PM
Posted 13 July 2012 - 05:54 PM
Posted 14 July 2012 - 08:15 AM
Could be wrong...
Posted 14 July 2012 - 09:32 AM
Posted 15 July 2012 - 12:38 PM
Posted 15 July 2012 - 01:09 PM
Posted 15 July 2012 - 05:59 PM
http://home.mindspri...taticTiming.pdf
Also check that your firing order is correct, 1-3-4-2 counterclockwise around the dizzy cap with #1 being about 2:00 on the dizzy cap and #1 cylinder being the one closest to the water pump. You can also be "out" 180 degrees so check to make sure you are making the ignition settings with #1 near TDC on its firing stroke. That is discussed in the PDF document.
Posted 15 July 2012 - 06:31 PM
Posted 15 July 2012 - 11:54 PM
Early Mini engines did not have timing marks on the pulley and timing chain cover. Their timing marks were on the flywheel and you have to remove a cover plate on the clutch cover to see the flywheel marks.
Any and all open ports on the carb and intake manifold should be capped when you are trying to start the engine.
If you find there are no timing marks on the flywheel, set the static timing to fire right at TDC. Then note exactly where the dizzy housing is and turn it clockwise an additional couple of degrees... let's say 3mm on the outside diameter of the dizzy housing. That should be close to 5 BTDC which should let you get the engine started. After that you can tune by ear. I leave guidance on that to others reading this thread as I don't do it that way.
You do not want to see bright sparks at the points. There should only be a small blue spark there. Big sparks at the points indicate something is wrong that will likely lead to quick wear and burning of the points.
You have referenced .8mm. That is not quite right for the spark plugs on a car with points and it is way wrong for the points themselves. The points should be set close to 0.015" or 0.016" (0.4mm). The spark plugs should be closer to 0.025" (0.64mm). When electronic ignitions are fitted you don't have the points to worry about and the change allows running wider spark plug gaps... but for points, keep the plug gaps closed up a little bit.
Finally, too much fuel is as bad as not enough. If this is an engine that has not run for a long time and whose carbs may have been sitting full of old fuel, make sure the float valves are set right and that they are properly closing off the fuel supply when the float is up.
Posted 16 July 2012 - 05:52 PM
Posted 24 July 2012 - 08:24 PM
Posted 25 July 2012 - 01:12 AM
Do you now have spark and is it happening at the correct time?
If you have spark, try pouring a thimble of fuel down the carb throat. If the engine starts and promptly dies, you have a fuel delivery problem, not an ignition problem.
Posted 29 July 2012 - 04:16 PM
