Mini Phoenix Project (fibreglass)
#16
Posted 18 March 2006 - 08:45 AM
#17
Posted 18 March 2006 - 05:31 PM
spoke to the guys at min-its and there taking back the coilovers and im getting some Koni supersport adjustables, hi-lows, new knuckle joints and some new nylon radius arm cups.
Hopefully this should sort me out without ripping the top mounts away from the rest of the car!!!!!
Goodbye little coilovers it just wasnt meant to be!
Tommorow is rear backplates and full drum assembly time so hopefully with the new supsension arriving tuesday the rear frame can be bolted back up.
Simon
#18
Posted 18 March 2006 - 06:22 PM
Will these stop coilovers from going through the arch?
Shocker mounts
And are coilovers better than normal suspension?
anyone?
#19
Posted 18 March 2006 - 06:27 PM
bolts through the top of the wheel arch itself.
#20
Posted 18 March 2006 - 06:33 PM
i knew that
#21
Posted 18 March 2006 - 06:35 PM
#22
Posted 18 March 2006 - 10:32 PM
1. Coilovers on front normal on back
2. Coilovers all round
3. Or adjustable suspension all round
#23
Posted 19 March 2006 - 09:02 AM
Simon
right im off to build up the rear frame!
#24
Posted 19 March 2006 - 10:52 PM
or do you have to leave them in?
#25
Posted 20 March 2006 - 07:00 PM
Simon
#26
Posted 20 March 2006 - 10:52 PM
to the 4 mounting points that locate the front of the subframe, you
could the do away withthe standard sub frame therefore losing a
lot of uneccesary weight
or you could fit a beam axle.
Added a rough scetch of an alternative radius arm mounting
Posted 21 March 2006 - 09:11 PM
ive now got the radius arms all sorted and the back plates built up. There all attached to the rear frame and its poly bushed up. Brake lines and braided hoses are on and the new hi-lows, rubber donuts and konis are bolted on.
Shes now ready to be mounted back on the car. It almost looks to nice and shiney to put back on!!
heres a pic
Simon
Posted 22 March 2006 - 11:40 PM
(it will be lower than this when i've finished restoring it!)
i plan on coilovers all round because i want to feel every bump in the road! i also plan on back problems by the age of 27! fiberglass shells are good because you loose alot of weight but are limited on certian things you can fit, like coilovers. hijack over! nice project will be nice to see what you do with this
#29
Posted 23 March 2006 - 09:08 AM
#30
Posted 27 March 2006 - 10:12 PM
I like!!!!!!!!!!!!
May be easier to buy than make !
p.s is there much clearence between the shock and the arch?
