Running Rough After Restarting When Warm?
Posted 02 July 2012 - 02:44 PM
Any ideas what it could be? Thanks!
Posted 02 July 2012 - 04:20 PM
The fuel comes through to the carb float bowl relatively cool but if the float bowl is very hot from the exhaust manifold heat radiation this cool fuel can vaporize before it gets to the engine, hence the initial poor running.
Hope this helps!
Steve.
Posted 02 July 2012 - 04:22 PM
Posted 02 July 2012 - 05:13 PM
Anyone got any solutions?
Posted 03 July 2012 - 09:21 AM
If you start it from warm after several minutes or more standing and it does this, you could have a case of fuel evaporation due to excessive heat build up with the engine off.
Hope this helps!
Steve.
Thanks, i mite try insulating the bowl.
I sometimes get this if I stop for say 10 minutes after being fully warmed up, it won't really idle and is really rough but it goes away once you get going
Unfortunetly this does not go away even after 15 minutes driving trying to limp home.
Any other ideas out there?
Posted 03 July 2012 - 09:31 AM
Posted 03 July 2012 - 03:24 PM
Thanks for the suggestion, ill look into the fueling. Im using a hif44 carb so that would not have a waxstat would it?Sounds more like wrong fueling, you can have this problem with too rich mixture or when waxstat starts playing up.
Posted 03 July 2012 - 03:37 PM
Usually if the engine is struggling to start when warm it could well be that its too rich, if it starts ok, but then runs rough, its most likely an ignition problem (coil, ignition module or points/condenser, wrong advance, worn plugs).
Could also be a combination of problems, this really needs further investigation.
Edited by jaydee, 03 July 2012 - 03:38 PM.
