Car Juddering At Around 30... [Video Included]
26 replies to this topic
#1 Wilhelm
Wilhelm
  • 103 posts
  • Local Club: Bomber County Mini's
Posted 22 June 2012 - 03:22 PM
Today I changed my ignition timing lamp arrived :D Thought would solve it, but it only made it run slightly better :(
When I'm driving at around 30 in 4th gear, the car judders quite a lot. It judders a fair bit in 3rd too.
If I rag it in 1st and 2nd then there's no juddering until I change up gear.
It also revs funny, the revs sometimes stutter, and when reving with the clutch down when driving it sometimes dosent rev very high.. :(
I got the igntion timing light to flash fastest when idling by turning the dizzy cap :S
Also, occasionally the car backfires. All sparkplugs and HT leads are in the right places.. :(
Video is uploading at the moment, will post as soon as it's done :)
The more detailed videos are in post 11. Help will be greatly appreciated :) :)
Edited by Wilhelm, 22 June 2012 - 06:14 PM.
#2 Chance
Chance
  • 1,457 posts
Posted 22 June 2012 - 03:36 PM
Sounds like what mine used to do. Would shake at low revs, if i revved hard in gears and then changed up it would shake too until i put my foot down.
Mine was misfiring due to a dodgy spark plug and also my points were in a pretty poor state.
New plugs, dizzy cap, points, condenser, coil, leads and it ran nicely again. Maybe your mixture needs adjusting aswell??
Im not certain though just sharing my experience, the experts will be along soon im sure (if they arent already here)
#3 Wilhelm
Wilhelm
  • 103 posts
skip to about 40 seconds in :)
#4 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 03:37 PM
Just changed the points over to electronic ignition, but i'll go have a look at the spark plugs, cheers :)
#5 coopdog
coopdog
  • 4,506 posts
Posted 22 June 2012 - 03:49 PM
well that misfire doesnt help
with the juddering that bad i'd try not to drive it as you could end up doind some nasty damage,
change the plugs and leads and everything else to do with the ignition,
is it burning oil at all?
Edited by coopdog, 22 June 2012 - 03:51 PM.
#6 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 04:09 PM
I don't think it's burning oil, I did a full service the other week with new oil/leads/plugs/airfilter/oilfilter ect..
Not driving it at the moment, using the bike instead until its sorted, but I need the car fixed for next week as I'm driving to the airport to go on holiday and the Mini is my only car :)
Got some photos of the sparkplugs, they seem greyish with a bit of pink? :/ Will upload in 2 mins :)
#7 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 04:11 PM
#8 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 04:17 PM
I'll add now that its a '81 Mini 1000 with a leaded head on, so I have to use the lead additive with fuel.
#9 coopdog
coopdog
  • 4,506 posts
Posted 22 June 2012 - 04:18 PM
plugs should be a biscuity colour
#10 Chance
Chance
  • 1,457 posts
Im going to explain a little more what happened to me, i might start rambling so bare with me
My engine mounts had gone so it shook the engine quite badly everytime it 'misfired'
I did the mounts and then when it misfired it just made a small jolt instead of shaking itself to bits
So all i can say is that it may be a misfire but it might shake because some mounts or stabiliser bushes have gone, but im still learning myself so could be miles off the track
plugs look ok to me, i think greyish means a lean mixture but no sure on this, i understand browny is healthy(i think)
#11 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 05:18 PM
Just been out looking at the car again with Dad, plugs all have plenty of spark and it only shakes really when at around 30, seems fine when reving it high at a standstill :) got some more vids on the way :)
#12 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 06:04 PM
The light for the ignition timer is actually flashing really fast, although you can't see it very well on the camera :) :)
#13 coopdog
coopdog
  • 4,506 posts
Posted 22 June 2012 - 06:20 PM
its not right because its missing like poop when your reving it,
you do know how to time an engine correctly dont you?
you dont go by how much the light is flashing :L
#14 Wilhelm
Wilhelm
  • 103 posts
Posted 22 June 2012 - 06:25 PM
Ooops... haha :D That's how I've been timing :D I just guessed really :D
#15 coopdog
coopdog
  • 4,506 posts
Posted 22 June 2012 - 06:28 PM
hahahaha thats EPIC,
ahhahahaah omg i cant believe you said that,
well i think thats your problem,
will try get a guide for you now if i can find one
