Micra Mini Track Day Car
232 replies to this topic
#181 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 09 November 2014 - 12:23 PM
it was rear heel board repair panels from MINI R US what i thought they were supplied by magnum there is no stickers on the panels to say they are metric i dident fit the drivers side one i had a look at it at work apparently a lot of panel manufactures use metric captive nuts now because its a lot cheaper to produce would of been nice if they put a sticker on it to tell you this, of course those who are experience enough like  yourself most likely can tell the difference between the two threads by looking at them. i have fitted loads of front panels what are clearly labelled M8 why should these heel board panels be any different.
#182 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 14 December 2014 - 08:13 PM
so after many many many months of the car doing sweet fa apart from being moved around a lot ........................................................... nothing has changed apart from a subframe jig has been constructed and a tube subframe being manufactured on it over Christmas exciting updates soon. i hoping this frame will be lighter, stronger and better looking than allspeeds offering as well as considerably cheaper  but time will tell...............
merry Christmas everyone hopefully big update in january 2015 for now i got a 1986 metro to attend to and get Pickuptruck1994 1959 racer to the autosport show fingers cross! one day i will get this car done i promise!
cheers Lucas
#183 miniobsessed
miniobsessed
  • 211 posts
Posted 17 December 2014 - 04:11 AM
Great work. Looking forward to the update!
#184 cb500t
cb500t
    Starting My Mini Up
  • 2 posts
Posted 19 December 2014 - 07:04 PM
Mighty interested if subframes are to be produced...brilliant read this,love it !
#185 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 19 December 2014 - 08:47 PM
plan is to produce the frames to order depending on the cost and effectiveness of the first prototype as soon as there is a development i will share pictures anyone interested in a subframe out of interest let me know so we can get a idea of potential market for the frame. Heres a picture of the car as its sat at the moment the frame in it was the first frame i made for a mock up it will go to the dump once the new one is complete   cheers luke
#186 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 31 December 2014 - 06:08 PM
happy new year! couple of cheeky pics of the jig and frame
5467EE18-CED4-49EF-81B4-21347B85D909_zps
CA0C39F2-DC25-4F10-91C2-F380C1C2AAEE_zps
B1F45468-34AF-461B-BB43-85E4213935DA_zps
F7AF40B2-A716-45C2-A443-D4784EBB2ECC_zps
EAF9AF34-2960-4E26-80DC-3FDBC7C65151_zps
A405D098-D269-4EA6-B6BD-6E596D72F529_zps
#187 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 06 January 2015 - 11:50 PM
frame is well on the way to being produced i can confirm copies of frame will be available to buy later on in the year once mine (001) has been completed for similar if not cheaper than allspeeds frame bonus being this frame will use standard mini arms not silly bent arms at £285+vat at set why re-invent the wheel if anyone has serious interest do get in touch. the frames would work on a exchange basis I.e we need a good standard front frame to begin with to modify on the jig
updates hopefully next week its tube bending time!
regards luke
#188 slack
slack
  • 65 posts
Posted 07 January 2015 - 12:01 AM
I'm interested. When you have the price for this tell me something. Do you sell also the driveshafts?
Thank you
#189 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 07 January 2015 - 12:03 AM
yes we can do the shafts as well
#190 slack
slack
  • 65 posts
Posted 07 January 2015 - 12:11 AM
Nice, when you have something please send me a message.
Thank you
#191 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 January 2015 - 12:28 AM
Looking forward to seeing the frame take shape. The jig seems to be doing it's job well!
Ben
#192 Artstu
Artstu
  • 832 posts
Posted 07 January 2015 - 11:41 AM
You need to get those top mounts integrated into the jig too, those rear legs are very flexible.
#193 l_jonez
l_jonez
  • 1,453 posts
Posted 07 January 2015 - 03:17 PM
Got to agree with this, the towers will lean forward as soon as you cut the sides out of the frame
#194 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 08 January 2015 - 12:23 AM
under the frame theres two captive nuts with bolts sticking out of them. the bolts are the same height so the frame sits on them so we can gauge any distortion or twist in the frame. when the frame was cut the frame lifted under the left tower by around 2mm. once the tube is bent the frame will be pulled down on to the captive bolts to make sure both towers are level. only then it will be welded first tacked dry fitted then seam welded. the towers will be connected via a anti roll bar shaped tube. before any more cutting is done as well as a temporary reinforcement plate under the rear mounting legs. this frame is a prototype but still want it to be a perfect as possible looking for another front subframe to make two as we go along!
#195 ibrooks
ibrooks
  • 1,017 posts
Posted 09 January 2015 - 09:33 AM
It's not just twist you need to watch for - they are quite often under a little tension side-to-side and when you cut things it allows this to move the weaker remaining structure and the towers can move further apart or closer together so you need to hold them in place until you have replaced the metal you cut out and the frame will hold itself in shape again. The holding device needs to be integrated into the jig so that you don't end up with both towers moving by the same amount in one direction (taking the top arms with them).
Iain
