What Does My Mini Weigh?
11 replies to this topic
#1 chrscmbs
chrscmbs
  • Validating
  • 138 posts
Posted 20 June 2012 - 01:14 PM
Hello,
Really quick question... what will my standard automatic 1984 austin mini mayfair weigh? I checked my log book but it does not say as such? any idea?
Kind regards
Chris.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 20 June 2012 - 01:27 PM
Saloon
Overall Length: 120.25 in (305mm)
Overall Width: 55.5 in (141mm)
Overall Height: 53 in (135mm)
Wheelbase: 80.15 in (203.6mm)
Kerb Weight (rubber cone suspension): 1294lb (587 kg)
Kerb Weight (hydrolastic suspension): 1398lb (634.5kg)
#3 chrscmbs
chrscmbs
  • Validating
  • 138 posts
Posted 20 June 2012 - 01:37 PM
thank you.
Chris.
#4 waddle
waddle
  • 536 posts
Posted 20 June 2012 - 01:48 PM
sorry to hijack, but is 500kg easy to get down to then? i thought 500 was the aim for most of the prople who are going light? , but it dosent sound like itd be hard to loose 87kg ?
#5 jakejakejake1
jakejakejake1
  • 644 posts
Posted 20 June 2012 - 01:54 PM
According to wikipedia, for mark 3 onwards -
848cc = 610kg
1275cc = 645kg
At the top of the page it also has this - Kerb weight 617 to 686 kg (1,360 to 1,512 lb)
But i think the later the car, the heavier it would be due to additions safety features etc
This means to get down to 500, your probably looking at around 120 kg minimum
Which is a fair bit given the trim/ useless stuff doesn't add up to much!
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 20 June 2012 - 02:32 PM
Is that right? 587kgs is a bit light I think. My super lightweight hillclimber, with titainium suspension, GRP doors, fron end, boot and all the metal possible removed is 545kgs.
I think 700kgs for a standard car is more likely, this is what my standard car weighs anyway (I weighed it)
#7 spaceframemini
spaceframemini
  • 383 posts
Posted 20 June 2012 - 02:54 PM
As will h said will be more like 700 there is nothing left on mine with everything removed carbon doors, front end, boot, boot floor and roof. again all alloy or titanium suspension and I still don't think it will be below 500
#8 waddle
waddle
  • 536 posts
Posted 20 June 2012 - 03:18 PM
im not even going to rty to get mine down to 500, although i recon you could save aload of weight out the engine as thats where all the weight seems to be
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 20 June 2012 - 04:28 PM
seems be loads of conflicting info on weights, I just picked those figures off a google search..
I just checked Haynes restoration manual and that give 1330 lb (604kg)
That first lot of figures I found seem to be mk1, wouldn't think it would be that big a difference
580 - 700 seems to be the range
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 20 June 2012 - 05:19 PM
The mini certainly got heavier through it's life, more soundproofing, biggerseats, more wiring, big servos, heater (not on an original 850), wing mirrors, windup windows, .........................................the list goes on.
700 is about right for a standard mini 80s on anyway.
#11 minimarco
minimarco
  • 1,950 posts
Posted 20 June 2012 - 05:24 PM
Just cut down on the chips.
#12 waddle
waddle
  • 536 posts
Posted 20 June 2012 - 05:32 PM
aha and a haircut before you get in ?
